Z170 Pro4S - Keeping tools and designs simple
What you've never understood about your computer is that it is scared to death of water, H2O, humidity or whatever you'd like to name it. And even though you do not see the water, actually there may be lots of excessive moist in the air killing your motherboard silently and slowly. No, your motherboard doesn't melt when in contact with water like the wicked witch of the west, but it dies of short circuit.
The power phase design offers smooth power delivery to the CPU, unmatched overclocking capabilities, lower temperature for advanced gamers, and reinforced system stability for taking on all sorts of arduous computing tasks.
Intel LAN provides the best throughput performance, lower CPU utilization, enhanced stability and is able to deliver ultimate network experience to users!
Supports 6th Generation Intel® Core™ Processors (Socket 1151)
Digi Power, 10 Power Phase Design
Supports Dual Channel DDR4 3200+(OC)
2 PCIe 3.0 x16, 3 PCIe 3.0 x1
AMD Quad CrossFireX™, CrossFireX™
Graphics Output Options: DVI-D, HDMI
7.1 CH HD Audio (Realtek ALC892 Audio Codec), ELNA Audio Caps
2 SATA Express, 6 SATA3, 1 Ultra M.2 (PCIe Gen3 x4 & SATA3)
8 USB 3.0 (2 Front, 6 Rear)
Supports Full Spike Protection, ASRock Live Update & APP Shop
- ASRock Z170 Pro4S - motherboard - ATX - LGA1151 Socket - Z170
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 8 x SATA-600 (RAID), 2 x SATA Express port, 1 x Ultra M.2
- Max Allocated RAM Size
- 1792 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- LGA1151 Socket
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 3200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0
Graphics
- 1792 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio, Premium Blu-ray audio support
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 2 x SATA Express port, 1 x Ultra M.2 - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Rapid Storage Technology
- 1 x PS/2 keyboard / mouse , 6 x USB 3.0 , 1 x HDMI , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 1 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x audio - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
- Manual Settings
- Processor core voltage, memory voltage
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- ASRock Instant Flash, Intel Turbo Boost Technology 2.0, Intel Smart Response Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, ASRock Dehumidifier Function, ASRock Fast Boot, ASRock UEFI System Browser, ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, 4K resolution support, Supports Intel K-Series unlocked CPU, ASRock BCLK, ELNA Audio Capacitors, ASRock Full Spike Protection, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock Full HD UEFI, ASRock My Favorites in UEFI, ASRock Easy RAID Installer, Nichicon 12K Platinum Caps, I/O Armor, ASRock Live Update, 10 Phase Power Design
- Included Accessories
- I/O back plate, 1 x M.2 screw
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASRock A-Tuning, ASRock Disk Health Report
- WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
