This board is designed to build up the most powerful system and delivers the most demanding technology for users nowadays. Just enjoy next generation computing with ASRock 8-core CPU ready motherboard.
All the capacitors on this board are built with 100% all solid capacitors. With these solid caps, ASRock's motherboards are allowed to perform more stably and ensure longer lifetime.
The technology that allows you to turn on your PC and boot up to Windows in 4 seconds! ASRock Instant Boot not only excels in the Boot Up speed (3~4 sec.), it also provides clean OS, and saves the most power energy.
AM3+ 8-core processor support
This board is designed to build up the most powerful system and delivers the most demanding technology for users nowadays. Just enjoy next generation computing with ASRock 8-core CPU ready motherboard. -
Combo cooler retention module
The unique combo cooler retention module greatly improves heat dissipation and is backward compatible with AMD previous AM3/AM2+ coolers. -
All solid capacitor design
All the capacitors on this board are built with 100% all solid capacitors. With these solid caps, ASRock's motherboards are allowed to perform more stably and ensure longer lifetime. -
4 USB 3.0
Rich storage options! This motherboard offers 4 USB 3.0 (2 from onboard header, 2 from rear I/O) to facilitate computing environment. -
Instant Boot
- ASRock N68-GS4/USB3 FX - motherboard - micro ATX - Socket AM3+ - GeForce 7025
- Product Type
- Motherboard - micro ATX
- Chipset Type
- NVIDIA GeForce 7025 / nForce 630a / NVIDIA nForce 630a MCP
- Processor Socket
- 1 x Socket AM3+
- Compatible Processors
- Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6 (Except Phenom II 920 / 940)
- Max RAM Size
- 16 GB
- RAM Supported
- 2 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-300 (RAID), 1 x ATA-133
- USB / FireWire Ports
- 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Graphics
- Max Allocated RAM Size
- 256 MB
- Audio
- HD Audio (6-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Max Bus Speed
- 1000 MHz
- Processor Socket
- Socket AM3+
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Graphics
- Graphics Controller
- Memory Allocation Technology
- Shared Video Memory (UMA)
- 256 MB
Audio
- Audio Codec
- Realtek ALC662
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8211E
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 1 x PCIe x16 , 1 x PCIe x1 , 2 x PCI , 2 x DIMM 240-pin
- Storage Interfaces
- SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 0+1 / RAID 5 / JBOD , ATA-133 -connectors: 1 x 40pin IDC - 2 devices
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x VGA , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 2 x USB 3.0
- Internal Interfaces
- 1 x floppy , 1 x parallel
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- ACPI support, JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, Untied Overclocking Technology
- Manual Settings
- Processor core voltage, memory voltage, chipset voltage
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- Chassis intrusion detection, ASRock Hybrid Booster, ASRock U-COP, AMD Cool 'n' Quiet Technology, ASRock Instant Boot, ASRock OC Tuner, 4+1 Phase Power Design, ASRock OC DNA, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, All-Solid Capacitor motherboard Design, ASRock Boot Failure Guard (B.F.G.), ASRock UCC, ASRock APP Charger, Asrock C.C.R. (Combo Cooler Retention Module), ASRock XFast LAN, ASRock XFast RAM, Preboot eXecution Environment (PXE)
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, Antivirus (Trial version), Start8 (30 days trial), Google Chrome Browser, Google ChromeToolbar
- Plug and Play, WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
