Your basket is empty
ASRock H110M-ITX Intel H110 1151 Mini ITX DDR4 DVI HDMI
Quicklinx: C382WS00 Mfr#: H110M-ITX
This motherboard's power phase design offers smooth power delivery to the CPU, unmatched overclocking capabilities, lower temperature for advanced gamers, and reinforced system stability for taking on all sorts of arduous computing tasks. This motherboard uses an advanced digital PWM (Pulse-Width Modulation) design, which provides CPU voltage more efficiently and smoothly, so that the stability and lifespan of the motherboard is greatly enhanced.
ASRock H110M-ITX - motherboard - mini ITX - LGA1151 Socket - H110
Motherboard - mini ITX
Chipset Type
Intel H110 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 3 x USB 2.0 via headers)
Max Allocated RAM Size
1792 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H110 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0
Graphics
1792 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio, Premium Blu-ray audio support
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode)
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
1 x PS/2 keyboard / mouse , 1 x DVI-D , 2 x USB 3.0 , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x HDMI
Internal Interfaces
2 x USB 3.0 - header , 3 x USB 2.0 - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
Multilingual BIOS, UEFI BIOS, SMBIOS 2.7 support, ACPI 5.0 support
Manual Settings
Processor core voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, opened case detection
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Chassis intrusion detection, ASRock Instant Flash, HDCP compliant, Intel Extreme Memory Profile (XMP) support, 5 Phase Power Design, ASRock APP Charger, Intel Turbo Boost Technology 2.0, Intel Clear Video HD Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ESD Protection, Dual-Stack MOSFET (DSM), ASRock Fast Boot, ASRock Restart to UEFI, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, CPU/Chassis Quiet Fan, CPU/Chassis Fan Multi-Speed Control, 4K resolution support, ELNA Audio Capacitors, ASRock A-Tuning, ASRock Full Spike Protection, ASRock Cloud, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock My Favorites in UEFI, ASRock Live Update
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, Antivirus (Trial version), Google Chrome Browser, Google ChromeToolbar, ASRock Disk Health Report
WHQL, FCC, EuP Ready, ErP Ready, ACPI 5.0
Package Type
Retail
