The technology that WOWs you with the ability to wake up your PC remotely over the internet. Turn your PC on/off only when you need to. Keep your PC healthy and save energy at the same time.
Who says high quality audio is only available on high-end motherboards? ASRock applied ELNA audio capacitors on mainstream and entry-level motherboards! Compared with traditional solid caps, the leakage current of ELNA audio caps is merely 3uA. This is the key to reduce noise level significantly and satisfy even the pickiest audiophiles.
This motherboard is compatible with both AMD FM2 and FM2+ APUs.
ASRock is determined to use high quality materials to build the best motherboards, that's why all the capacitors on this motherboard are built with 100% solid capacitors. These solid capacitors bring long lasting durability and ultra stable performance.
Complete with all three types of most used connectors! Packed with a D-Sub + DVI + HDMI combo. Plus the HDMI port supports Full HD 1080p Blu-ray (BD) playback.
4K is a standard for display resolutions with a minimum of 3840 x 2160 pixels, which is twice the horizontal and vertical resolution of the 1080p format and four times as many pixels overall. Get ready to lose yourself in this eye popping virtual reality.
This motherboard supports the next-gen PCIe 3.0! Compared to PCIe 2.0, PCIe 3.0 offers up to 2X data transferring bandwidth for VGA cards, thus providing ultimate graphics performance.
Brilliantly designed for smart overclocking, ASRock X-Boost Technology is able to unleash the hidden power of your CPUs. Simply press "X" when turning on the PC, X-Boost will automatically overclock the relative components to get up to 15.77% performance boost! With the smart X-Boost, overclocking CPU can become a near one-button process.
Protects the motherboard from excessive surges from the power supply unit.
The onboard LAN chip is protected against sudden and violent voltage spikes caused by lightning.
In a world where time is money, why waste precious time everyday typing usernames to log in? Why should one even bother memorizing those foot long passwords? Nobody has time for that! Just plug in the USB Key and let your computer log in automatically!
Fast Boot is so fast that it is impossible for users to enter the UEFI setup utility during POST. Therefore, ASRock Restart to UEFI technology allows users to easily enter the UEFI setup utility automatically when turning on the PC next time. It is designed for those who constantly need to enter the UEFI setup utility.
Limit and control your children's time spent on the Internet. ASRock OMG (Online Management Guard) technology allows you to establish an Internet curfew or restrict Internet access at specified times. Administrators are able to schedule the starting and ending hours of Internet access granted to other users.
Dampness kills most electronics, so it's a better idea to keep your personal computer dry. Now users may prevent motherboard damages due to dampness by enabling Dehumidifier. When it is enabled, the computer will power on automatically to dehumidify the system after entering S4/S5 state.
Wake On WAN
The technology that WOWs you with the ability to wake up your PC remotely over the internet. Turn your PC on/off only when you need to. Keep your PC healthy and save energy at the same time. -
ELNA audio caps
Who says high quality audio is only available on high-end motherboards? ASRock applied ELNA audio capacitors on mainstream and entry-level motherboards! Compared with traditional solid caps, the leakage current of ELNA audio caps is merely 3uA. This is the key to reduce noise level significantly and satisfy even the pickiest audiophiles. -
FM2/FM2+ APU support
This motherboard is compatible with both AMD FM2 and FM2+ APUs. -
All solid capacitor design
ASRock is determined to use high quality materials to build the best motherboards, that's why all the capacitors on this motherboard are built with 100% solid capacitors. These solid capacitors bring long lasting durability and ultra stable performance. -
3 graphics outputs
Complete with all three types of most used connectors! Packed with a D-Sub + DVI + HDMI combo. Plus the HDMI port supports Full HD 1080p Blu-ray (BD) playback. -
4K x 2K
4K is a standard for display resolutions with a minimum of 3840 x 2160 pixels, which is twice the horizontal and vertical resolution of the 1080p format and four times as many pixels overall. Get ready to lose yourself in this eye popping virtual reality. -
Next-Gen PCIe 3.0
This motherboard supports the next-gen PCIe 3.0! Compared to PCIe 2.0, PCIe 3.0 offers up to 2X data transferring bandwidth for VGA cards, thus providing ultimate graphics performance. -
X-Boost
Brilliantly designed for smart overclocking, ASRock X-Boost Technology is able to unleash the hidden power of your CPUs. Simply press "X" when turning on the PC, X-Boost will automatically overclock the relative components to get up to 15.77% performance boost! With the smart X-Boost, overclocking CPU can become a near one-button process. -
Surge protection
Protects the motherboard from excessive surges from the power supply unit. -
Lightning protection
The onboard LAN chip is protected against sudden and violent voltage spikes caused by lightning. -
USB Key
In a world where time is money, why waste precious time everyday typing usernames to log in? Why should one even bother memorizing those foot long passwords? Nobody has time for that! Just plug in the USB Key and let your computer log in automatically! -
Restart to UEFI
Fast Boot is so fast that it is impossible for users to enter the UEFI setup utility during POST. Therefore, ASRock Restart to UEFI technology allows users to easily enter the UEFI setup utility automatically when turning on the PC next time. It is designed for those who constantly need to enter the UEFI setup utility. -
Limit and control your children's time spent on the Internet. ASRock OMG (Online Management Guard) technology allows you to establish an Internet curfew or restrict Internet access at specified times. Administrators are able to schedule the starting and ending hours of Internet access granted to other users. -
Dehumidifier
- ASRock FM2A88M Pro3+ - motherboard - micro ATX - Socket FM2+ - AMD A88X
- Product Type
- Motherboard - micro ATX
- Chipset Type
- AMD A88X
- Processor Socket
- 1 x Socket FM2+
- Compatible Processors
- (Maximum TDP 100 Watt)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 8 x SATA-600 (RAID)
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (1 x USB 3.0 + 2 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2 GB
- Audio
- HD Audio (6-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- AMD A88X
- Processor Socket
- Socket FM2+
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2400 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- 2 GB
Audio
- Audio Codec
- Realtek ALC662
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111GR
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 8 x 7pin Serial ATA - 8 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 2 x USB 3.0 , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x DVI-D (dual link) , 1 x VGA , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (front surround) - mini-jack , 1 x PS/2 mouse , 4 x USB 2.0
- Internal Interfaces
- 2 x USB 3.0 - header , 4 x USB 2.0 - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
- Manual Settings
- Processor core voltage, memory voltage, chipset voltage
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- Chassis intrusion detection, ASRock Hybrid Booster, ASRock U-COP, ASRock Instant Boot, Trusted Platform Module (TPM), ASRock Instant Flash, All-Solid Capacitor motherboard Design, HDCP compliant, Intel Extreme Memory Profile (XMP) support, ASRock APP Charger, ASRock XFast USB, AsRock On/Off Play Technology, AMD Radeon Dual Graphics, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, 4+2 Phase Power Design, ASRock Dehumidifier Function, Easy RAID Installer, AMD Steady Video 2.0, ASRock Interactive UEFI, AMD Memory Profile (AMP) support, ASRock Fast Boot, ASRock X-Boost, ASRock Restart to UEFI, ASRock UEFI System Browser, ASRock Home Cloud, ASRock FAN-Tastic Tuning, Energy Efficient Ethernet 802.3az, ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, CPU/Chassis Quiet Fan, CPU/Chassis Fan Multi-Speed Control, Triple Monitor, Premium Headset Amplifier, ASRock A-Tuning, ASRock Full Spike Protection, ASRock Cloud, ASRock APP Shop
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, Antivirus (Trial version), Start8 (30 days trial), Google Chrome Browser, Google ChromeToolbar, Orbweb.ME Professional (Win 8.1)
- Plug and Play, WHQL, FCC, EuP Ready, ErP Ready
- 22.4 cm
- 20.3 cm
