Product
Brand
ASRock FM2A88M EXTREME4+ AMD FM2+ A88M DDR3 mATX
Quicklinx: 935CWS00 Mfr#: FM2A88M EXTREME4+
This motherboard supports Security Wake On Internet technology with the onboard Qualcomm Atheros LAN, so you can connect with your PC from anywhere in the world. You will be able to power your PC on or turn it off, monitor and take control of it remotely with another smartphone, tablet or computer.
ASRock is determined to use high quality materials to build the best motherboards that are why all the capacitors on this motherboard are built with 100% solid capacitors. These solid capacitors bring long lasting durability and ultra stable performance.
This ASRock motherboard supports the PCI-E 3.0! PCI Express 3.0 can maximize the bandwidth of the PCI Express 3.0 VGA cards, thus providing ultimate graphics performance.
ASRock FM2A88M Extreme4+ - motherboard - micro ATX - Socket FM2+ - AMD A88X
Motherboard - micro ATX
Chipset Type
AMD A88X
Processor Socket
1 x Socket FM2+
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A88X
Processor Socket
Socket FM2+
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
2400 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2600 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
2 GB
Audio
Audio Codec
Realtek ALC892
High Definition Audio, Premium Blu-ray audio support
LAN
Network Controller
Atheros AR8171
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 (FM2+ processor must be installed) , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - 8 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x TOSLINK , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack
Internal Interfaces
1 x parallel - header , 1 x serial - header , 3 x USB 2.0 - header , 1 x USB 3.0 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, opened case detection
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, AMD Cool 'n' Quiet Technology, ASRock Instant Boot, ASRock Instant Flash, All-Solid Capacitor motherboard Design, HDCP compliant, Intel Extreme Memory Profile (XMP) support, ASRock APP Charger, ASRock XFast USB, AsRock On/Off Play Technology, AMD Radeon Dual Graphics, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, 4+2 Phase Power Design, ASRock Dehumidifier Function, Easy RAID Installer, AMD Steady Video 2.0, ASRock Interactive UEFI, AMD Memory Profile (AMP) support, ASRock Fast Boot, ASRock X-Boost, ASRock Restart to UEFI, ASRock UEFI System Browser, ASRock Home Cloud, ASRock FAN-Tastic Tuning, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, CPU/Chassis Fan Multi-Speed Control, Triple Monitor, CPU Quiet Fan, ASRock A-Tuning
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, Cyberlink MediaEspresso 6.5 (30-day trial), Antivirus (Trial version), Start8 (30 days trial)
WHQL, FCC, EuP Ready, ErP Ready
