Fatal1ty Z97X Killer: A high-end Z97 Gaming MB with Killer LAN, M.2 socket, and SATA Express interface
- ASRock Super Alloy
- XXL Aluminum Alloy Heatsink
- Premium Alloy Choke (Reduces 70% core loss compared to iron powder choke)
- Dual-Stack MOSFET (DSM)
- NexFET™ MOSFET
- Nichicon 12K Platinum Caps (100% Japan made high quality conductive polymer capacitors)
- Sapphire Black PCB
- Supports 5th Generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® Processors (Socket 1150)
- Supports New 4th and 4th Generation Intel® Xeon®/Core™ i7/i5/i3/Pentium®/Celeron® Processors (Socket 1150)
- Digi Power, 8 Power Phase design
- Supports Dual Channel DDR3 3200+(OC)
- 3 PCIe 3.0 x16, 3 PCIe 2.0 x1
- Supports AMD 3-Way CrossFireX™ and NVIDIA® Quad SLI™
- Graphics Output Options: D-Sub, DVI-D, HDMI
- 7.1 CH HD Audio with Content Protection (Realtek ALC1150 Audio Codec), Supports DTS Connect
- 1 SATA Express, 6 SATA3, 1 M.2 (PCIe Gen2 x2 & SATA, Supports 30mm, 42mm, 60mm, 80mm, 110mm M.2 devices), 8 USB 3.0 (2 Front, 6 Rear), 6 USB 2.0 (4 Front, 1 Rear, 1 Fatal1ty Mouse Port)
- 1 COM Port Header
- Supports ASRock HDD Saver Technology, Full Spike Protection, ASRock Cloud, APP Shop, F-Stream, Key Master, Full HD UEFI
Gaming Armor
- CPU Power - Hi-Density Power Connector
- Memory - 15µ Gold Contact in DIMM Slots
- VGA Card - 15µ Gold Contact in VGA PCIe Slot (PCIE2), PCIe Power Connector
- Internet - Qualcomm® Atheros® Killer™ LAN
- Audio - Purity Sound™ 2
Fast networking performance
Delivering faster networking performance for time-sensitive UDP (User Datagram Protocol) based applications, such as online games and high quality media streaming. -
Killer network manager
Use Qualcomm Atheros Killer network manager to classify and prioritize online games, HD video and high quality audio for better quality and fewer interruptions in your online experience. -
XXL aluminum alloy heatsink design
The extra large aluminum alloy heatsinks take away heat dramatically. As the MOSFETs and chipsets areas are well covered by these heatsinks to protect them from overheating, CPU and chipsets can perform with lower temperature, and your motherboard and system will be more stable and reliable. -
Premium alloy choke
The alloy chokes effectively increase up to 90% saturation current and feature a highly magnetic and heat resistant design, making the motherboard more efficient, stable and reliable. -
Dual-Stack MOSFET for CPU power
Dual-Stack MOSFET (DSM) is another innovative MOSFETs design by ASRock. The silicon die area is increased by stacking two dies into one MOSFET. The larger the die area, the lower Rds (on). -
NexFET MOSFET for memory power
The NexFET MOSFETs control the power supply to DRAM slots more efficiently. They provide lower RDS (on) 2.9 mO, delivering higher efficiency and lower temperature. -
12K platinum caps
Supreme 12K platinum capacitors with lifespans of at least 12,000 hours. Compared to other counterparts on high-end motherboards that merely have lifespans of around 10,000 hours, these platinum capacitors have 20% longer lifespans and provide more stability and reliability. -
M.2 socket
The onboard M.2 socket is interface for connecting Next Generation Form Factor (NGFF) solid state drives or other devices. ASRock supports M.2 SATA3 6 Gb/s modules and M.2 PCI Express modules up to Gen2 x2 10 Gb/s, which is 2x faster compared to other M.2 Gen2 x1 solutions that are limited to 5 Gb/s. -
Purity Sound 2
Purity Sound 2 includes 7.1 CH HD audio with Realtek ALC1150 audio codec, 115 dB SNR DAC with differential amplifier, TI NE5532 premium headset amplifier, cap less Direct Drive technology, EMI shielding cover, PCB isolate shielding and DTS connect. As Nichicon audio capacitors are what every audiophile has been longing for on a PC, ASRock applied these high quality capacitors for Purity Sound 2. -
Key master
What good is a weapon if you are unable to wield it proficiently? Key master consists of two major features, sniper key and macro key. It can enhance your mouse and keyboard with customizable macros, sniper modes, key repeat rates and repeat delay, turning your boring old keyboard and mouse into lethal weapons. Key Master may be prohibited by some games. -
XSplit
XSplit Broadcaster is a desktop application designed to make your multimedia broadcasting, live-streaming and recording a lot easier and more fun. XSplit Gamecaster is a simplified version of XSplit Broadcaster. -
Fatal1ty Mouse Port
Fatal1ty Mouse Port is a customizable technology for PC gamers that is a part of F-Stream. After plugging the USB mouse into the Fatal1ty Mouse Port and running F-Stream, gamers can use Fatal1ty's personal preferred mouse polling rate at 500 Hz. F-Stream also provides the flexibility for gamers to adjust the mouse polling rate from 125 Hz to 1000 Hz. This is helpful for professional gamers to experience smoother game play and faster response time. -
F-Stream
F-Stream is Fatal1ty's multi purpose software suite with an interface, more features and improved utilities, including Key Master, Fatal1ty Mouse Port, EZ OC, Auto Tuning, XFast RAM, OC Tweaker, System Browser, Live Update, Tech Service and a whole lot more! -
Digi power - more precise, more efficient
Unlike traditional motherboards that use analog power, this motherboard uses a next generation digital PWM (Pulse-Width Modulation) design, which provides CPU Vcore voltage more efficiently and smoothly, so that the stability and lifespan of the motherboard is greatly enhanced. -
SATA Express connector
The SATA Express interface provides PCIe Gen2 x2 (10 Gb/s) data transfer speed. This motherboard offers the latest SATA Express connector to enthusiasts to enjoy the ultimate performance. -
HDD Saver technology
There's a dedicated 4-pin HDD Saver Connector placed near the SATA ports. By connecting it to the HDDs, you can shut down or turn on the HDDs via software when needed. HDD Saver Technology secures more privacy, saves more energy, and extends HDD life. -
High density glass fabric PCB
What you've never understood about your computer is that it is scared to death of water, H2O, humidity or whatever you'd like to name it. And even though you do not see the water, actually there may be lots of excessive moist in the air killing your motherboard silently and slowly. No, your motherboard doesn't melt when in contact with water like the wicked witch of the west, but it dies of short circuit. Luckily, ASRock has a High Density Glass Fabric PCB design that reduces the gaps between the PCB layers to protect the motherboard against electrical shorts caused by humidity. -
ASRock OMG (Online Management Guard)
Limit and control your children's time spent on the Internet. ASRock OMG (Online Management Guard) technology allows you to establish an Internet curfew or restrict Internet access at specified times. Administrators are able to schedule the starting and ending hours of Internet access granted to other users. -
Easy driver installer
For users that don't have an optical disk drive to install the drivers from the support CD, easy driver installer is a handy tool in the UEFI that installs the LAN driver to your system via an USB storage device, then downloads and installs the other required drivers automatically through the Internet. Completely no CD or optical disk drive required! -
DTS connect
Tired of listening to audio that makes your ears bleed? Experience high-quality surround sound from your personal computer. DTS connect is a blanket name for a two-part system, including DTS interactive and DTS Neo: PC, it is used on the computer platform only, in order to convert PC audio into the DTS format. -
HDMI
This motherboard supports HDMI (High-Definition Multimedia Interface) which is an interface standard for transferring uncompressed video data and delivering multi-channel audio through a single cable. Both video and audio data signals transferred through the HDMI interface is digital without being converted into analog, therefore it delivers the richest pictures and the most realistic sounds.
- ASRock Z97X Killer - motherboard - ATX - LGA1150 Socket - Z97
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z97 Express
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Xeon, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 6 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1792 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z97 Express
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 2133 MHz (O.C.), 1866 MHz (O.C.), 3200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1792 MB
Audio
- Audio Codec
- Realtek ALC1150
- DTS Connect, High Definition Audio, Premium Blu-ray audio support
LAN
- Network Controller
- Killer Gaming E2200
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 3.0 x16 (dual: x8 mode; triple: x8, x4, x4 mode; single card: x16 mode) , 3 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Rapid Storage Technology
- 1 x PS/2 keyboard / mouse , 2 x USB 2.0 , 1 x VGA , 1 x HDMI , 1 x DVI-D , 6 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 1 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x serial - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- NVIDIA SLI Technology Support, 8 Phase Power Design, ASRock Instant Flash, HDCP compliant, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASRock APP Charger, Intel Turbo Boost Technology 2.0, Intel Clear Video HD Technology, Intel Smart Response Technology, Conductive Polymer Capacitors, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, Fatal1ty Mouse Port, Fatal1ty F-Stream, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASRock Dehumidifier Function, Dual-Stack MOSFET (DSM), Easy RAID Installer, ASRock Restart to UEFI, ASRock UEFI System Browser, ASRock Purity Sound, Platform Controller Hub (PCH) 1.05V Voltage Multi-adjustment, Platform Controller Hub (PCH) 1.5V Voltage Multi-adjustment, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, CPU/Chassis Quiet Fan, CPU/Chassis Fan Multi-Speed Control, ASRock Key Master, Triple Monitor, Supports Intel K-Series unlocked CPU, ASRock BCLK, Premium Alloy Chokes (PAC), Premium Headset Amplifier, Direct Drive Technology, NexFET, ASRock Full Spike Protection
- Included Accessories
- I/O back plate, ASRock SLI_Bridge_2S Card
- Cables Included
- 4 x Serial ATA cable
- Software Included
- Drivers & Utilities, Antivirus (Trial version), Start8 (30 days trial), Killer Network Manager, Google Chrome Browser, Google ChromeToolbar
- WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
