Product
Brand
ASRock B150M Pro4S Intel B150 S1151 DDR4 USB3.0 mATX
Quicklinx: BM2NWS00 Mfr#: B150M Pro4S
What you've never understood about your computer is that it is scared to death of water, H2O, humidity or whatever you'd like to name it. And even though you do not see the water, actually there may be lots of excessive moist in the air killing your motherboard silently and slowly. No, your motherboard doesn't melt when in contact with water like the wicked witch of the west, but it dies of short circuit. Luckily, ASRock has a high density glass fabric PCB design that reduces the gaps between the PCB layers to protect the motherboard against electrical shorts caused by humidity.
The power phase design offers smooth power delivery to the CPU, unmatched overclocking capabilities, lower temperature for advanced gamers, and reinforced system stability for taking on all sorts of arduous computing tasks.
ASRock B150M Pro4S - motherboard - micro ATX - LGA1151 Socket - B150
Motherboard - micro ATX
Chipset Type
Intel B150 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600
USB / FireWire Ports
4 x USB 3.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1792 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel B150 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0
Graphics
1792 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio, Premium Blu-ray audio support
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices
1 x PS/2 keyboard / mouse , 1 x HDMI , 1 x DVI-D , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x USB 3.0 - header , 1 x USB 2.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
UEFI BIOS, SMBIOS 2.7 support, ACPI 5.0 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Instant Flash, HDCP compliant, Intel Extreme Memory Profile (XMP) support, ASRock APP Charger, 6 Phase Power Design, Intel Turbo Boost Technology 2.0, Intel Clear Video HD Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASRock Dehumidifier Function, ASRock Fast Boot, ASRock Restart to UEFI, Energy Efficient Ethernet 802.3az, ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, 4K resolution support, ELNA Audio Capacitors, ASRock Full Spike Protection, ASRock Cloud, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock Full HD UEFI, ASRock My Favorites in UEFI, I/O Armor, ASRock Live Update
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, Antivirus (Trial version), Google Chrome Browser, Google ChromeToolbar, ASRock Disk Health Report
WHQL, FCC, EuP Ready, ErP Ready, ACPI 5.0
