Aruba MSM720 Premium Mobility Controller
Quicklinx: 8YZSWS00 Mfr#: J9694A
The HPE MSM Controller Series works in unison with IEEE 802.11a/b/g/n and .11ac HPE access points and access devices to deliver a cost effective, high-performance, networking solution for the mid-size enterprise campus. The enhanced architecture supports next generation standards, RF optimization and flexible distribution models for unparalleled performance, reliability and ease of deployment. The solution provides comprehensive security, threat protection and high availability to provide business continuity.
  • Optimized Design and Performance
    The HPE Multiservice Mobility Controller Series supports both centralized and distributed forwarding options to reduce latency, optimize application performance and increase WLAN scalability.Optimizes wireless coverage and the user experience with Wi-Fi Clear Connect RF optimization, automatic interference mitigation and dynamic client load balancing to increase connectivity.Offers flexible upgrade licensing to scale the network as business requirements change.Comes in appliance or blade form factors and supports 802.11a/b/g/n and 802.11ac clients.
  • Simplicity and Low Total Cost of Ownership (TCO)
    The HPE Multiservice Mobility Controller Series simplifies configuration and deployment of WLAN services with automated workflows.Reduces complexity by streamlining configuration, management and troubleshooting of multivendor wired/WLAN networks with HPE single management tool.Lowers total cost of ownership (TCO) with Industry leading warranties.Analytics and monitoring dashboard offers a quick view of the health of the WLAN and potential issues with intuitive visibility into Wireless Clients, APs and alarms.
  • Business Continuity
    The HPE Multiservice Mobility Controller Series delivers seamless failover of mobility services through virtual controller redundancy.Offers comprehensive security and threat protection with integrated intrusion detection system (IDS), support for internal and external authentication, authorization and accounting (AAA) servers, and a stateful built-in firewall.Supports comprehensive identity management, endpoint security, and centralized policy enforcement for a converged wired/wireless infrastructure.
HPE MSM720 Premium Mobility Controller (WW) - network management device
Network management device
External
Ports Qty
6
Manageable access points: 40 , Simultaneous users: 250 , MAC addresses: 12000
Power Over Ethernet (PoE) Supported
PoE
16 cm x 25.4 cm x 4.4 cm
1.6 kg
16 cm
25.4 cm
4.4 cm
1.6 kg
External
Ports Qty
6
Wired
Data Transfer Rate
1 Gbps
Auto-sensing per device, power over Ethernet (PoE), manageable, half duplex mode, full duplex mode, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af
6 x 1000Base-T - RJ-45 , 1 x management - DB-9
Rack Mounting Kit
Optional
CISPR 22 Class A, ICES-003, EN55024, EN55022 Class A, AS/NZS 3548, UL 60950-1, FCC Part 15 A
PoE
External power adapter
6 Watt
5 °C
45 °C
20 - 90%
8YZS C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
8YZS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
8YZS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.95
8YZS C2G 2m Cat6a Shielded Patch - Blue In Stock £7.33
