The HPE MSM Controller Series works in unison with IEEE 802.11a/b/g/n and .11ac HPE access points and access devices to deliver a cost effective, high-performance, networking solution for the mid-size enterprise campus. The enhanced architecture supports next generation standards, RF optimization and flexible distribution models for unparalleled performance, reliability and ease of deployment. The solution provides comprehensive security, threat protection and high availability to provide business continuity.
Optimized Design and Performance
The HPE Multiservice Mobility Controller Series supports both centralized and distributed forwarding options to reduce latency, optimize application performance and increase WLAN scalability.Optimizes wireless coverage and the user experience with Wi-Fi Clear Connect RF optimization, automatic interference mitigation and dynamic client load balancing to increase connectivity.Offers flexible upgrade licensing to scale the network as business requirements change.Comes in appliance or blade form factors and supports 802.11a/b/g/n and 802.11ac clients. -
Simplicity and Low Total Cost of Ownership (TCO)
The HPE Multiservice Mobility Controller Series simplifies configuration and deployment of WLAN services with automated workflows.Reduces complexity by streamlining configuration, management and troubleshooting of multivendor wired/WLAN networks with HPE single management tool.Lowers total cost of ownership (TCO) with Industry leading warranties.Analytics and monitoring dashboard offers a quick view of the health of the WLAN and potential issues with intuitive visibility into Wireless Clients, APs and alarms. -
Business Continuity
The HPE Multiservice Mobility Controller Series delivers seamless failover of mobility services through virtual controller redundancy.Offers comprehensive security and threat protection with integrated intrusion detection system (IDS), support for internal and external authentication, authorization and accounting (AAA) servers, and a stateful built-in firewall.Supports comprehensive identity management, endpoint security, and centralized policy enforcement for a converged wired/wireless infrastructure.
- HPE MSM775 zl Premium Controller Module - network management device - Wi-Fi
- Network management device
- Form Factor
- Plug-in module
- Processor
- 1 x Intel Core i3 2.4 GHz
- RAM
- 4 GB
- Hard Drive
- 32 GB x 1
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Capacity
- Manageable access points: 200
- 20.65 cm x 24.77 cm x 4.45 cm
- 1.2 kg
- Limited lifetime warranty
- 20.65 cm
- 24.77 cm
- 4.45 cm
- 1.2 kg
Processor / Memory / Storage
- Processors Installed
- Max Supported Qty
- 1
- RAM
- 4 GB DDR3 SDRAM SO-DIMM 204-pin
- Hard Drive
- SSD 32 GB x 1
- Form Factor
- Plug-in module
- Capacity
- CISPR 22 Class A, ICES-003, EN55022 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, CAN/CSA-C22.2 No. 60950-1
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 15 - 95% (non-condensing)
