Your basket is empty
Aruba HP MSM720 Premium Mobility Controller
Quicklinx: 8YZSWS00 Mfr#: J9694A
Type: Network management device
Connectivity: Wired
Speed: 1Gbps
Protocol: Gigabit Ethernet
Compatibility: PC
£1,843.43 ex VAT
£2,212.11 inc VAT
The HPE MSM Controller Series works in unison with IEEE 802.11a/b/g/n and .11ac HPE access points and access devices to deliver a cost effective, high-performance, networking solution for the mid-size enterprise campus. The enhanced architecture supports next generation standards, RF optimization and flexible distribution models for unparalleled performance, reliability and ease of deployment. The solution provides comprehensive security, threat protection and high availability to provide business continuity.
HPE MSM720 Premium Mobility Controller (WW) - network management device
External
Ports Qty
6
Manageable access points: 40 , Simultaneous users: 250 , MAC addresses: 12000
Power Over Ethernet (PoE) Supported
PoE
16 cm x 25.4 cm x 4.4 cm
1.6 kg
16 cm
25.4 cm
4.4 cm
1.6 kg
External
Ports Qty
6
Wired
Data Transfer Rate
1 Gbps
Auto-sensing per device, power over Ethernet (PoE), manageable, half duplex mode, full duplex mode, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af
6 x 1000Base-T - RJ-45 , 1 x management - DB-9
Rack Mounting Kit
Optional
CISPR 22 Class A, ICES-003, EN55024, EN55022 Class A, AS/NZS 3548, UL 60950-1, FCC Part 15 A
PoE
External power adapter
6 Watt
5 °C
45 °C
20 - 90%
8YZS C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.30
8YZS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.25
8YZS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.51
8YZS C2G 2m Cat6a Shielded Patch - Blue In Stock £7.51
8YZS C2G TruLink Media Gateway RJ45 Cap In Stock £0.58
8YZS C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.56
Connectivity: Wired
Speed: 1Gbps
Compatibility: PC
Brand: Aruba
Price Range Ex VAT: 1500+
