The HPE MSM 802.11n Dual Radio Access Point Series works in unison with the HPE controllers to deliver a high performance WLAN solution. Offering near gigabit client access and increased reliability they are ideal for voice and multi-media communications while providing full compatibility with legacy 802.11 clients and existing HPE wireless controllers. Built-in Spectral Analysis and integrated Wireless IDS/IPS provides detection, classification and intelligent avoidance of non-802.11 interference and comprehensive threat protection. Access points can be deployed in managed or autonomous mode.
Enhanced Wi-Fi Performance
The HPE MSM 802.11n Dual Radio Access Point Series is the first of three spatial stream 802.11n access point product in the industry to deliver near gigabit client access for enhanced voice and rich media applications.It can support both centralized and distributed traffic forwarding, offering enhanced application performance and WLAN scalability.Provides advanced QoS for voice and video communication supporting IEEE 802.1p traffic priority handling for Microsoft , Lync , and Spectralink Voice Priority (SVP).Extends network availability with self-healing, self-optimizing local mesh. -
Improved Coverage and Reliability
The HPE MSM 802.11n Dual Radio Access Point Series optimizes WLAN coverage and reliability with Wi-Fi Clear Connect automatic power adjustment, real-time identification of interference, and intelligent channel switching.Enhances the user experience with airtime fairness, providing equal RF transmission time for wireless clients in mixed client environments.The series extends RF coverage with transmit beamforming and improve client performance by automatically redirecting 5 GHz-capable clients to the less-congested 5 GHz spectrum.Supports concurrent 5 GHz operation (MSM466 and MSM466-R) improving noise immunity, and channel availability in high density Wi-Fi environments. -
Comprehensive Security
The HPE MSM 802.11n Dual Radio Access Point Series provides comprehensive threat protection with integrated IDS offering, granular threat detection and location tacking capabilities.Simplifies client authentication with support internal and external authentication, authorization and accounting servers (AAA), per user VLAN mapping and authentication.Locks out unauthorized wireless access by authenticating users prior to granting network access and secures data integrity of wireless traffic with Advanced Encryption Standard (AES) or Temporal Key Integrity Protocol (TKIP). -
Investment Protection
The HPE MSM 802.11n Dual Radio Access Point Series provides indoor 802.11n Dual Radio access points and delivers Limited Lifetime Warranty.Provides interoperability with all IEEE 802.11a/b/g/n client devices through Wi-Fi Alliance certifications.
- HPE MSM460 Dual Radio 802.11n AP (WW) - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- VoIP calls: 12
- Included Accessories
- 2 x ceiling mounting clip
- Power Over Ethernet (PoE) Supported
- PoE
- 13.2 cm x 15.6 cm x 4.9 cm
- 330 g
- Limited lifetime warranty
- 13.2 cm
- 15.6 cm
- 4.9 cm
- 330 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 450 Mbps
- Remote Management Protocol
- SNMP 3, SNMP 2c
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- VoIP calls: 12
- Auto-uplink (auto MDI/MDI-X), Intrusion Detection System (IDS), Intrusion Prevention System (IPS), IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support
- Encryption Algorithm
- AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2, MD2
- Authentication Method
- RADIUS, PAP, CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 801.1p, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 6
- Directivity
- Omni-directional
- 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
- Mounting Kit
- Included
- FCC Class B certified, EN55022 Class B, ICES-003 Class B, FCC Part 15.247, RSS-210, RSS-102, FCC Part 15, MIC, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, CSA C22.2 No. 60950-1, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
- PoE
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
