Entry consolidation and virtualization initiatives are now well in your budgetary reach. The HPE MSA 1040 Storage offers many of the HPE MSA 2040 features but at a substantially lower entry price points. HPE ProLiant and BladeSystems administrators as well as IT generalists will find storage management tasks simple and intuitive with MSA. The MSA 1040 arrays leverage a new 4th-generation controller architecture with a new processor, 2-host ports and 4GB cache per controller. Take advantage of the latest hard drives advances by choosing the form factor and technology which best meet your application and budget requirements. Unlike many competing arrays, the MSA 1040 ships standard with intuitive management tools and powerful data services such as Snapshots and Volume Copy for increased data protection.
Simple: Flexible Architecture
The integrated setup and management Web-based Interface (WBI) makes MSA easy to manage for HPE ProLiant/BladeSystems administrators and IT generalists.Leverage the latest Large or Small Form Factor hard disk drives –choice of High-performance Enterprise-class SAS or high-capacity SAS Midline drives based on application, performance and budget requirements.On-board management tools augment OS and hypervisor views navigate firmware upgrades, monitor array performance with ease locally or remotely. -
Affordable: Popular iSCSI/SAS/Fibre Channel Configurations
Dual controller configurations are standard and available at single controller price points.More capacity/performance within your budget.Latest MSA technology at lower cost. -
Fast: The MSA 1040 Delivers up to 50% More Performance Compared to P2000 G3
The HPE MSA 1040 SAN Storage leverages the 4th generation MSA architecture, 2-port controllers with 4 GB Cache each, faster processor and a performance optimized I/O engine.Increased performance translates into better application response times and facilitates entry consolidation and virtualization initiatives. -
Futureproof: Built-in Expandability Along with an HPE MSA 2040 Upgrade Option
Add Disk Enclosures as needed to boost capacity and spindle count. Most low-cost entry arrays don't allow expansion.Data-in-Place upgrades eliminate time-consuming and risky data migrations.HPE MSA 1040 SAN Storage allow simple controller swap to flagship HPE MSA 2040. Other value-priced arrays force you to compromise.
- HPE Modular Smart Array 1040 Dual Controller LFF Storage - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Max Supported Capacity
- 48 TB
- Interface
- 8Gb Fibre Channel
- Maximum LUNs
- 512
- Storage Controller
- RAID (SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 50
- Storage Controller Quantity
- 2
- Hard Drive
- No HDD
- OS Required
- Red Hat Linux, SUSE Linux Enterprise Server, Microsoft Windows Server 2008 SP2, Microsoft Windows Server 2012
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 48.26 cm x 57.2 cm x 8.9 cm
- 3-year warranty
- Hard drive array
- Enclosure Type
Storage
- 48 TB
- HDD Array External Interface
- 8Gb Fibre Channel
- Maximum LUNs
- 512
Storage Controller
- RAID
- Installed Qty
- 2
- Interface Type
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Cache / Buffer Size (Max)
- 4 GB
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- No HDD
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 3.5" LFF
- 4 x 8Gb Fibre Channel - RJ-45 , 2 x USB (management) , 2 x Ethernet 1000Base-T (management) - RJ-45 , 2 x SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
- OS Required
- Firmware upgradable
- FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 61000-3-2, GS, EN 61000-3-3, EN55022 Class A, CCC, FCC Part 15, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, WEEE, RoHS, EN55024 Class A, VCCI Class A, KN24, KN22 Class A, China RoHS, CNS 13438
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 337 Watt
- 48.26 cm
- 57.2 cm
- 8.9 cm
- Limited warranty - parts - 3 years
- 5 °C
- 40 °C
- 10 - 90% (non-condensing)
