Your basket is empty
Aruba HP 525 Wireless 802.11ac (WW) Access Point
Quicklinx: BGMNWS00 Mfr#: JG994A
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£327.32 ex VAT
£392.78 inc VAT
The HPE 525 802.11ac Dual Radio Access Points Series supports two spatial streams offering 867 Mbps performance, faster application processing, and increased range to 802.11 clients. Ideal for dense client environments and high-bandwidth applications, the series can be powered by PoE and offers full compatibility with legacy 802.11 clients and existing HPE wireless controllers. The series works with HPE Unified Wireless LAN Controllers to provide automatic detection, classification, and intelligent mitigation of non-IEEE 802.11 interference and comprehensive threat protection.
HPE 525 (WW) - radio access point
Radio access point
In-ceiling - indoor
1 x 720 MHz
RAM
256 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE
22 cm x 22 cm x 6 cm
750 g
Radio access point
Ruggedized Design
Indoor
22 cm
22 cm
6 cm
750 g
Processor / Memory / Storage
Processors Installed
1 x 720 MHz
RAM
256 MB SDRAM
Flash Memory
128 MB
In-ceiling
Wireless
Network / Transport Protocol
DHCP
Remote Management Protocol
SNMP 3, SNMP 2c
Frequency Band
2.4 GHz, 5 GHz
MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), plenum-rated, Wi-Fi Clear Connect
Encryption Algorithm
MD5, SSL, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WEP
Authentication Method
RADIUS, PAP, CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1i, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External detachable and internal
Antenna Qty
8
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 4 x aerial - RP-SMA
EN55022 Class B, ICES-003 Class B, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, CAN/CSA C22.2 No. 60950-1, iDA, EN 300 328
PoE
Limited warranty - advance parts replacement - lifetime - response time: next business day
45 °C
5 - 95% (non-condensing)
BGMN C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.30
BGMN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.25
BGMN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.51
BGMN C2G 2m Cat6a Shielded Patch - Blue In Stock £7.51
BGMN C2G TruLink Media Gateway RJ45 Cap In Stock £0.58
BGMN C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.56
Compatibility: PC
Brand: Aruba
Price Range Ex VAT: 300 - 500
