The HPE 425 802.11n Dual Radio Access Point Series works in unison with HPE network controllers to deliver a high performance WLAN solution. Offering two spatial stream access and up to 300 Mbps of throughput per radio, they are ideal for voice and multi-media communications and offer embedded high gain and optional external antennas for improved wireless coverage and reliability. Built-in spectral analysis and integrated wireless IDS/IPS provides detection, classification and intelligent avoidance of non-IEEE 802.11 interference and comprehensive threat protection.
Enhanced Wi-Fi Performance
The HPE 425 802.11n Dual Radio Access Point Series offers dual radio, two spatial stream access, supporting up to 300 Mbps per radio for enhanced voice and rich media applications.Supports both centralized and distributed traffic forwarding offering enhanced application performance and WLAN scalability.Provides advanced Quality of Service (QoS) for voice and video communication supporting IEEE 802.1p traffic priority handling and Spectralink Voice Priority (SVP).Extends network availability with self-healing, self-optimizing local mesh. -
Improved Coverage and Reliability
The HPE 425 802.11n Dual Radio Access Point Series optimizes WLAN coverage and reliability with Wi-Fi Clear Connect automatic power adjustment capability, providing real-time identification of interference, and intelligent channel switching.Enhances the user experience with airtime fairness, providing equal RF transmission time for wireless clients in mixed user environments.Improves client performance by automatically redirecting 5 GHz-capable clients to the less-congested 5 GHz spectrum with band steering.Improves wireless coverage in dense client environments with embedded high gain internal antennas and optional external antennas. -
Comprehensive Security
The HPE 425 802.11n Dual Radio Access Point Series provides comprehensive threat protection with an integrated Intrusion Detection System (IDS) offering granular threat detection and location tacking capabilities.Simplifies client authentication with support for both internal and external authentication, authorization and accounting servers (AAA), per user VLAN mapping and authentication.Locks out unauthorized wireless access by authenticating users prior to granting network access. Enhance data integrity of the wireless traffic with Advanced Encryption Standard (AES) or Temporal Key Integrity Protocol (TKIP). -
Investment Protection
The HPE 425 802.11n Dual Radio Access Point Series provides a Limited Lifetime Warranty.Provides interoperability with all IEEE 802.11a/b/g/n client devices through Wi-Fi Alliance certifications.
- HPE 425 (WW) - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External - indoor
- Processor
- 1 x 560 MHz
- RAM
- 128 MB
- Flash Memory
- 128 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Included Accessories
- 2 x ceiling mounting clip
- Power Over Ethernet (PoE) Supported
- PoE
- 18.86 cm x 18.86 cm x 5.08 cm
- 750 g
- Limited lifetime warranty
- Ruggedized Design
- Indoor
- 18.86 cm
- 18.86 cm
- 5.08 cm
- 750 g
Processor / Memory / Storage
- Processors Installed
- 1 x 560 MHz
- RAM
- 128 MB
- Flash Memory
- 128 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- DHCP
- Remote Management Protocol
- SNMP 3, SNMP 2c
- Communication Mode
- Half-duplex, full-duplex
- Frequency Band
- 2.4 GHz, 5 GHz
- DHCP support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, Intrusion Detection System (IDS), wall mountable, Wi-Fi Multimedia (WMM) support, SpectraLink Voice Priority (SVP) support, Quality of Service (QoS), plenum-rated, ceiling mountable, Wi-Fi Clear Connect, Virtual Service Community (VSC)
- Encryption Algorithm
- AES, SSL, TKIP, WPA, WPA2, WEP
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Directivity
- Omni-directional
- 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
- EN55022 Class B, ICES-003 Class B, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, UL 2043, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC CFR47, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, iDA, EN 300 328, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- PoE
- Power Device
- External power adapter (not included)
- Max Supported Qty
- 1
- Software Included
- HP Intelligent Management Center, HP Wireless Services Manager
- Limited warranty - lifetime - response time: next business day , Technical support - phone consulting - lifetime
- 0 °C
- 45 °C
- 5 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
