Product
Aruba HP 2530-48-PoE+ Switch
Quicklinx: 92ZFWS00 Mfr#: J9778A
Type: Fast Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£1,199.70 ex VAT
£1,439.64 inc VAT
The Aruba 2530 Switch Series provides security, reliability, and ease of use for enterprise edge, branch office, and SMB deployments. Fully managed switches deliver Layer 2 capabilities with optional PoE+, optional 10GbE uplinks, enhanced access security, traffic prioritization, sFlow, IPv6 host support, and power savings with Energy Efficient Ethernet. The Aruba 2530 Switch Series is easy to use and deploy, and delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management.
  • Cost-Effective, Reliable and Secure Access Layer Switches
    The Aruba 2530 Switch Series provides security, reliability, and ease of use for enterprise edge, branch office, and SMB deployments.Fully managed switches deliver full Layer 2 capabilities with optional PoE+, enhanced access security, traffic prioritization, sFlow, and IPv6 host support.Right size deployment with choice of 8-, 24-, and 48-port models available with Gigabit or Fast Ethernet ports, and optional PoE+.Power savings with fanless models, Energy Efficient Ethernet (IEEE 802.3az), and ability to disable LEDs and enable port low power mode.Delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager, Airwave and cloud-based Central. Provides optimal configuration automatically when connected to Aruba access points for PoE priority, VLAN configuration, and rogue AP containment.
  • Security and Quality of Service (QoS)
    The Aruba 2530 Switch Series supports flexible authentication methods including Local MAC, 802.1X, and MAC and Web for greater policy-driven application security.Advanced denial of service (DOS) protection, such as DHCP Protection, Dynamic ARP protection, and Dynamic IP lockdown, enhance security. Flexible traffic controls include ACLs and QoS.Traffic prioritization with IEEE 802.1p allows real-time traffic classification with support for eight priority levels mapped to either two or four queues using weighted deficit round robin (WDRR) or strict priority (SP).Defend your IPv6 network with DHCPv6 Protection.
  • Simple Deployment and Management
    The Aruba 2530 Switch Series supports a choice of management interfaces with Web GUI, command-line interface (CLI), and SNMP with either console or micro USB ports.Quiet operation with fanless and variable speed fan models.Flexible deployment with wall, table, and rack mounting options.TR-069 delivers zero touch deployment for devices with dynamic IP addresses and on private networks.
  • Single View of the Network
    The Aruba 2530 Switch Series supports ClearPass Policy Manager for unified and consistent policy between wired and wireless users and simplifies implementation and management of guest login, user onboarding, network access, security, QoS, and other network policies.Supports Airwave Network Management software to provide common platform for Zero-Touch Provisioning management, and monitoring for wired and wireless network devices.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms, and events.Aruba Central cloud-based management platform offers simple, secure, and cost effective way to manage switches.Supports both cloud-based Central and on-premise AirWave with the same hardware ensuring change of management platform without ripping and replacing switching infrastructure.
HPE Aruba 2530-48-PoE+ - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 + 2 x Gigabit SFP + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
Performance
Throughput: 13 Mpps , Switching capacity: 17.6 Gbps
MAC addresses: 16000
MAC Address Table Size
16000 entries
Jumbo Frame Support
9220 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH-2, CLI
Flow control, DHCP support, BOOTP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, IPv6 support, half duplex mode, full duplex mode, SNTP support, sFlow, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), STP Root Guard, LLDP support, Class of Service (CoS), Generic Attribute Registration Protocol (GARP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44.2 cm x 32.26 cm x 4.45 cm
4.58 kg
Enclosure Type
Desktop, rack-mountable, wall-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
Performance
16000 entries
Jumbo Frame Support
9220 bytes
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x ARM: 800 MHz
RAM
256 MB DDR3 SDRAM
Flash Memory
128 MB
2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x SFP (mini-GBIC) , 1 x management RJ-45 , 48 x 10Base-T/100Base-TX - RJ-45
Internal power supply
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, EN 60825, CSA C22.2 No. 60950-1
44.2 cm
32.26 cm
4.45 cm
4.58 kg
Limited warranty - lifetime
45 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
92ZF C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
92ZF C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.35
92ZF C2G 2m Cat6a Shielded Patch - Blue In Stock £6.98
Type: Fast Ethernet
Ports: 48
Managed: Yes
POE: PoE+
Brand: Aruba
Price Range Ex VAT: 1000 - 1500
