Your basket is empty
Aruba HP 225 Instant 802.11ac (WW) Access Point
Quicklinx: BGMFWS00 Mfr#: JL190A
Type: Radio access point
Connectivity: Wireless
Speed: 1.3Gbps
Protocol: IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£658.69 ex VAT
£790.42 inc VAT
With a maximum data rate of 1.3 Gbps in the 5-GHz band and 600 Mbps in the 2.4-GHz band, 220 series APs are three-times faster than 802.11n APs and provide performance similar to a wired connection.
Instant 225 APs include ClientMatch technology, which eliminates sticky clients by continuously gathering session performance metrics from mobile devices. This information is then used to steer each mobile device to the best AP and radio on the WLAN.
Proactive and deterministic, ClientMatch dynamically optimizes Wi-Fi client performance as users roam and RF conditions change. If a mobile device moves out of range of an AP or RF interference impedes performance, ClientMatch automatically steers it to a better AP.
With ClientMatch, Instant 225 APs load web pages faster, deliver video streams with improved quality and support high densities of mobile devices. An 802.11ac network without ClientMatch performs no different than an 802.11n WLAN. The Instant 225 APs additionally support priority handling and policy enforcement for individual Microsoft Lync media on the same device, including encrypted videoconferencing, voice, chat and desktop sharing.
HPE 225 Instant (WW) - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets
Power Over Ethernet (PoE) Supported
PoE+
20.3 cm x 20.3 cm x 5.4 cm
750 g
Radio access point
Ruggedized Design
Indoor
20.3 cm
20.3 cm
5.4 cm
750 g
External
Wireless
Data Transfer Rate
1.3 Gbps
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, system, wireless, link/activity
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, wall mountable, Trusted Platform Module (TPM), reset button, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC), dual-band 802.11n, 3T3R MIMO technology, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), security lock slot (cable lock sold separately), Advanced Cellular Coexistence (ACC), ClientMatch, Broadcom TurboQAM technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
2 x 1000Base-T (PoE+) - RJ-45 , 1 x management - RJ-45 , 1 x USB 2.0 - Type A
Mounting brackets
EN 60950, IEC 60950, UL 60950, CB, EN 300.328, UL 2043, FCC, R&TTE, EN 301.893, EN 60601-1-2, cTUVus, EN 60601-1, FIPS, LVD, Directive 72/23/EEC
PoE+
50 °C
5 - 95% (non-condensing)
BGMF C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.30
BGMF C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.25
BGMF C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.51
BGMF C2G 2m Cat6a Shielded Patch - Blue In Stock £7.51
BGMF C2G TruLink Media Gateway RJ45 Cap In Stock £0.58
BGMF C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.56
Speed: 1.3Gbps
Compatibility: PC
Brand: Aruba
Price Range Ex VAT: 500 - 750
