Your basket is empty
Aruba HP 103 Instant 802.11n (WW) Access Point
Quicklinx: BGMBWS00 Mfr#: JL188A
  • IEEE 802.11n
These compact and cost-effective APs deliver wireless data rates up to 300 Mbps per radio employing 802.11n technology with two spatial MIMO streams. Instant 103 features a 2.4-GHz and a 5-GHz radio, each with 2 x 2:2 MIMO and two integrated dual-band omni-directional downtilt antennas.
HPE 103 Instant (WW) - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets
Power Over Ethernet (PoE) Supported
PoE+
15 cm x 15 cm x 4.15 cm
300 g
Radio access point
Ruggedized Design
Indoor
15 cm
15 cm
4.15 cm
300 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, link OK, system, wireless
Auto-uplink (auto MDI/MDI-X), DFS support, Trusted Platform Module (TPM), reset button, 2T2R MIMO technology, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC), dual-band 802.11n, Low Density Parity Check (LDPC), Direct Sequence Spread Spectrum (DSSS), optimised for Microsoft Lync, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), security lock slot (cable lock sold separately), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T (PoE+) - RJ-45 , 1 x management
Mounting brackets
EN 60950, IEC 60950, IEC 60601-1-1, UL 60950, CB, FCC, EN 301.893, EN 60601-1-2, cTUVus, Directive 72/23/EEC, EN 300 328
PoE+
5 - 95% (non-condensing)
BGMB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.08
BGMB C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.53
BGMB C2G 2m Cat6a Shielded Patch - Blue In Stock £6.47
BGMB C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.04
