Aruba 560 Wireless 802.11ac
Quicklinx: 9R01WS00 Mfr#: J9846A
  • IEEE 802.11n
The HPE 560 802.11ac Dual Radio Access Point Series brings 1.3 GbE performance, faster application processing and increased range to 802.11 clients. Ideal for dense client environments and high-bandwidth applications, these access points are powered by PoE and offer full compatibility with legacy 802.11 clients and existing HPE wireless controllers. Built-in Spectral Analysis and integrated Wireless IDS/IPS provide detection, classification and intelligent avoidance of non-802.11 interference and comprehensive threat protection. Access points can be deployed in managed or autonomous mode.
  • Optimized Performance for Rich Media and BYOD
    The HPE 560 802.11ac Dual Radio Access Point Series delivers the latest in Wi-Fi technology, offering 1.3 Gbps in the 5 GHz frequency band and 450 Mbps in the 2.4 GHz band for high-bandwidth applications and BYOD.Supports both centralized and distributed traffic forwarding for unparalleled application performance and WLAN scalability.Provides advanced quality of service (QoS) for voice and video communications with support for rate limiting, IEEE 802.1p traffic prioritization and Spectralink Voice Priority (SVP).Extends network availability with self-healing, self-optimizing local mesh.
  • Improved Coverage and Reliability
    The HPE 560 802.11ac Dual Radio Access Point Series optimizes WLAN coverage and reliability with Wi-Fi Clear Connect automatic power adjustment, real-time identification of interference, and intelligent channel switching.Enhances the user experience with airtime fairness, providing equal RF transmission time for wireless clients in mixed client environments.Extends RF coverage with transmit beamforming and improves client performance by automatically redirecting 5 GHz-capable clients to the less-congested 5 GHz spectrum.
  • Comprehensive Security
    The HPE 560 802.11ac Dual Radio Access Point Series provides comprehensive threat protection with integrated IDS/IPS offering granular threat detection and location tacking capabilities.Simplifies client authentication with support for internal and external authentication, authorization and accounting servers, and per user VLAN mapping and authentication.Locks out unauthorized wireless access by authenticating users prior to granting network access and secures the data integrity of wireless traffic with Advanced Encryption Standard (AES) or Temporal Key Integrity Protocol (TKIP).
  • Investment Protection
    The HPE 560 802.11ac Dual Radio Access Point Series has a Limited Lifetime Warranty.The series provides interoperability with all IEEE 802.11a/b/g/n/ac client devices through Wi-Fi Alliance certifications.It eliminates the need to upgrade to PoE+ by fully powering 5Ghz 802.11ac radio with 802.11af PoE and adapting 2.4 GHz radio to available 802.11af PoE.
HPE 560 (WW) - radio access point - Wi-Fi 5
Radio access point
External
1 x 800 MHz
RAM
256 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16 , VoIP calls: 12
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE+
20.32 cm x 17.15 cm x 6.65 cm
1.02 kg
Radio access point
20.32 cm
17.15 cm
6.65 cm
1.02 kg
Processor / Memory / Storage
Processors Installed
1 x 800 MHz
RAM
256 MB
Flash Memory
128 MB
External
Wireless
Remote Management Protocol
SNMP 3, SNMP 2c, HTTPS
Communication Mode
Half-duplex, full-duplex
Frequency Band
2.4 GHz, 5 GHz
Power over Ethernet (PoE), load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, Intrusion Detection System (IDS), Intrusion Prevention System (IPS), IP address filtering, MIMO technology, Wi-Fi Multimedia (WMM) support, SpectraLink Voice Priority (SVP) support, Quality of Service (QoS), PoE+, ceiling mountable, Wi-Fi Clear Connect, Virtual Service Community (VSC)
Encryption Algorithm
MD5, AES, SSL, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WEP
Authentication Method
RADIUS, PAP, CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
1 x 1000Base-T - RJ-45 , 1 x serial - RJ-45
FCC Class B certified, ICES-003 Class B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, FCC Part 15, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC CFR47, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, CSA C22.2 No. 60950-1, iDA, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
PoE+
14 Watt
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - phone consulting - lifetime
50 °C
5 - 95% (non-condensing)
