Aruba 525 Wireless 802.11ac (WW) Access Point
Quicklinx: BGMNWS00 Mfr#: JG994A
  • IEEE 802.11n
The HPE 525 802.11ac Dual Radio Access Points Series supports two spatial streams offering 867 Mbps performance, faster application processing, and increased range to 802.11 clients. Ideal for dense client environments and high-bandwidth applications, the series can be powered by PoE and offers full compatibility with legacy 802.11 clients and existing HPE wireless controllers. The series works with HPE Unified Wireless LAN Controllers to provide automatic detection, classification, and intelligent mitigation of non-IEEE 802.11 interference and comprehensive threat protection.
  • Optimized Performance for Rich Media and BYOD
    The HPE 525 802.11ac Dual Radio Access Point Series delivers the latest in Wi-Fi technology, offering up to 867 Mbps in the 5 GHz frequency band and up to 300 Mbps in the 2.4 GHz band for high-bandwidth applications and BYOD.Supports both centralized and distributed traffic forwarding for unparalleled application performance and WLAN scalability.It provides advanced quality of service (QoS) for voice and video communications with support for rate limiting and IEEE 802.1p traffic prioritization and Spectralink Voice Priority (SVP).Extends network availability with self-healing, self-optimizing local mesh.
  • Improved Coverage and Reliability
    The HPE 525 802.11ac Dual Radio Access Point Series optimizes WLAN coverage and reliability with Wi-Fi Clear Connect automatic power adjustment, real-time identification of interference, and intelligent channel switching.Enhances the user experience with airtime fairness, providing equal RF transmission time for wireless clients in mixed client environments.Improves client performance by automatically redirecting 5 GHz-capable clients to the less-congested 5 GHz spectrum.Provides excellent coverage through use of embedded high-gain antennas and optional external antennas.
  • Comprehensive Security
    The HPE 525 802.11ac Dual Radio Access Point Series provides comprehensive threat protection with integrated IDS/IPS offering granular threat detection, mitigation and location tracking capabilities.It can simplify client authentication for support of internal and external authentication, authorization and accounting servers (AAA), and per user VLAN mapping and authentication.Locks out unauthorized wireless access by authenticating users prior to granting network access and secure data integrity of the wireless traffic with Advanced Encryption Standard (AES) or Temporal Key Integrity Protocol (TKIP).
  • Investment Protection
    The HPE 525 802.11ac Dual Radio Access Point Series has a Limited Lifetime Warranty.The series provides interoperability with all IEEE 802.11a/b/g/n/ac client devices through Wi-Fi Alliance certifications.It reduces the need to upgrade to PoE+ by fully powering both radios with 802.11af PoE.
HPE 525 (WW) - radio access point
Radio access point
In-ceiling - indoor
1 x 720 MHz
RAM
256 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE
22 cm x 22 cm x 6 cm
750 g
Radio access point
Ruggedized Design
Indoor
22 cm
22 cm
6 cm
750 g
Processor / Memory / Storage
Processors Installed
1 x 720 MHz
RAM
256 MB SDRAM
Flash Memory
128 MB
In-ceiling
Wireless
Network / Transport Protocol
DHCP
Remote Management Protocol
SNMP 3, SNMP 2c
Frequency Band
2.4 GHz, 5 GHz
MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), plenum-rated, Wi-Fi Clear Connect
Encryption Algorithm
MD5, SSL, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WEP
Authentication Method
RADIUS, PAP, CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1i, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External detachable and internal
Antenna Qty
8
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 4 x aerial - RP-SMA
EN55022 Class B, ICES-003 Class B, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, CAN/CSA C22.2 No. 60950-1, iDA, EN 300 328
PoE
Limited warranty - advance parts replacement - lifetime - response time: next business day
45 °C
5 - 95% (non-condensing)
BGMN C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
BGMN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
BGMN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.95
BGMN C2G 2m Cat6a Shielded Patch - Blue In Stock £7.33
