Aruba 225 Instant 802.11ac (WW) Access Point
Quicklinx: BGMFWS00 Mfr#: JL190A
  • IEEE 802.11n
With a maximum data rate of 1.3 Gbps in the 5-GHz band and 600 Mbps in the 2.4-GHz band, 220 series APs are three-times faster than 802.11n APs and provide performance similar to a wired connection.
Instant 225 APs include ClientMatch technology, which eliminates sticky clients by continuously gathering session performance metrics from mobile devices. This information is then used to steer each mobile device to the best AP and radio on the WLAN.
Proactive and deterministic, ClientMatch dynamically optimizes Wi-Fi client performance as users roam and RF conditions change. If a mobile device moves out of range of an AP or RF interference impedes performance, ClientMatch automatically steers it to a better AP.
With ClientMatch, Instant 225 APs load web pages faster, deliver video streams with improved quality and support high densities of mobile devices. An 802.11ac network without ClientMatch performs no different than an 802.11n WLAN. The Instant 225 APs additionally support priority handling and policy enforcement for individual Microsoft Lync media on the same device, including encrypted videoconferencing, voice, chat and desktop sharing.
  • Allows phased wired infrastructure upgrades
    Adapts to available 802.3af power-over-Ethernet (PoE) instead of requiring customers to upgrade to 802.3at PoE+.
  • Delivers 1.9 Gbps aggregate throughput
    EtherChannel link aggregation on two Gigabit Ethernet ports provides 1.9 Gbps throughput.
  • 600 Mbps in the 2.4-GHz band
    Supports up to 600 Mbps for TurboQAM-enabled mobile devices operating in the 2.4-GHz band - an industry first.
  • Best-in-class RF management
    Integrated Adaptive Radio Management technology manages the 2.4-GHz and 5-GHz radio bands and ensures that APs stay clear of RF interference.
  • Spectrum analysis
    Capable of part-time or dedicated air monitoring, the spectrum analyzer remotely scans the 2.4-GHz and 5-GHz radio bands to identify sources of RF interference.
  • Wireless mesh
    Wireless mesh connections are convenient where Ethernet drops are not available.
HPE 225 Instant (WW) - radio access point - Wi-Fi 5
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets
Power Over Ethernet (PoE) Supported
PoE+
20.3 cm x 20.3 cm x 5.4 cm
750 g
Radio access point
Ruggedized Design
Indoor
20.3 cm
20.3 cm
5.4 cm
750 g
External
Wireless
Data Transfer Rate
1.3 Gbps
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, system, wireless, link/activity
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, wall mountable, Trusted Platform Module (TPM), reset button, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC), dual-band 802.11n, 3T3R MIMO technology, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), security lock slot (cable lock sold separately), Advanced Cellular Coexistence (ACC), ClientMatch, Broadcom TurboQAM technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
2 x 1000Base-T (PoE+) - RJ-45 , 1 x management - RJ-45 , 1 x USB 2.0 - Type A
Mounting brackets
EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, R&TTE, EN 60601-1-2, cTUVus, EN 60601-1, FIPS, LVD, Directive 72/23/EEC, EN 300 328, EN 301 893
PoE+
50 °C
5 - 95% (non-condensing)
BGMF C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
