Arlo Ultra 4K UHD HDR Wire-Free Security 2-Camera System
Quicklinx: FH74WS00 Mfr#: VMS5240-100EUS
Arlo Ultra
Cutting edge protection for what matters most
Crystal clear 4K image quality
While typical security camera footage is infamous for its low fidelity, the Arlo Ultra camera and SmartHub deliver high performance 4K HDR that ensures cutting-edge image quality.
Advanced dewarping
Get a more complete picture of your property with a 180-degree diagonal field of view—and without the typical fisheye distortion.
4K video with HDR
See more details in a wide range of light conditions, from bright highlights to dark shadows.
Close-up zoom
High resolution 4K video reveals key image details, including words, logos and license plates.
A spotlight that never sleeps
Ward off unwelcome guests with Arlo Ultra's powerfully bright, motion-activated spotlight.
Enhanced color night vision
The integrated spotlight allows you to see video in color rather than traditional black and white.
Auto-zoom and tracking
Arlo Ultra intelligently adjusts to movement, focusing its frame on what matters.
Keep watch without wires
Wire-free and WiFi enabled, Arlo Ultra camera goes anywhere you need to protect your home.
On guard rain or shine
Arlo Ultra camera is weather-resistant so it works indoors or out in rain, sleet or snow.
It's your eyes. And ears.
Listen and speak with anyone in range of your Arlo Ultra with clear, full 2-way audio.
A smarter home siren
Set your siren to sound automatically, or trigger it from your phone upon receiving an alert.
Pristine audio adds powerful security
Arlo Ultra features dual, noise-cancelling microphones that reduces distracting background noises like wind, rain and street activity, providing you clearer distortion-free sound.
2 Camera System - What's included:
2 Cameras + battery
1 Power Adapter
1 Magnetic Charge Cable
1 Ethernet Cable
1 Magnetic Mount
1 Quarter Twenty Mount
2 Wall Mount Screw Kit
1 Quick Start Guide
1 Decal
1 Ultra SmartHub (VMB5000)
  • 4K with HDR
    Zoom 12x with 180° view and auto image correction.
  • Motion alerts
    Get alerts to your phone if motion is detected.
  • Auto zoom and tracking
    Auto-focus and follow moving objects.
Arlo Ultra 4K UHD Wire-Free Security Camera System - gateway + camera(s) - wireless (802.11b, 802.11g, 802.11n, 802.11ac, Bluetooth 4.2)
System
Gateway + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Camera
2 cameras - outdoor - night vision
White
Europe
1 year
System
Network Interface
microSD card slot, motion detection, 4K Ultra HD video, High Dynamic Range (HDR), two-way audio support, spotlight, 12x digital zoom
Package Content
Power adapter, mounting screws, 2 camera batteries, magnetic charging cable, video monitoring decal, SmartHub, 2 x camera wall mounts
Network cable - 1 pcs.
White
Europe
Warranty
1 year
Security DVR
Compression Format
H.264, H.265
Cameras
Quantity
2 cameras
Camera Type
Outdoor
Sensor
1/2" - 8 Megapixel
Field of View
180°
Night Vision
White Balance
Auto
Gain Control
Auto
Voltage
DC 5 V
-20 °C
60 °C
Details
Camera: 5.2 cm x 7.84 cm x 8.9 cm - 331 g
FH74 Arlo Solar Panel Charger - Gen2 White - forArlo Go 2, Pro 3, Pro 4, Ultra, Floodlight In Stock £49.99
