Arlo Q Plus VMC3040S Network Surveillance Camera
Quicklinx: CD8DWS00 Mfr#: VMC3040S-100EUS
  • microSDHC Card
  • microSD Card
Arlo Q Plus 1080p HD security camera is the perfect security monitoring solution for your business. With 1080p HD video and 2-way audio capability, you won't have to be there to see and hear everything in perfect detail. Arlo Q Plus offers flexible setup options, so you can power up using the included power adapter or a PoE switch. Connecting the camera to the cloud can also be done flexibly through WiFi or Ethernet. Additionally, the SD card slot provides local recording in case of Internet interruptions. Just like the rest of the Arlo camera family, Arlo Q Plus is packed with amazing features such as night vision, motion and sound alerts, smart scheduling, and FREE cloud video recording. Add up to 5 cameras to one account and enjoy rolling storage for your motion and sound triggered recordings in past 7 days at no cost.
Arlo Q Plus VMC3040S - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
6.985 cm x 7.112 cm x 11.43 cm
167.82 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS
Ethernet 10Base-T/100Base-TX, IEEE 802.11n
Platform
IFTTT
Intelligent Assistant
Google Assistant, Alexa
1 - USB cable - external
E-mail alerts, manually schedule recording, Motion Detection Technology, Push Notification, Live Streaming, sound sensor, cloud recording
Audio Support
Wired, wireless
6.985 cm
7.112 cm
11.43 cm
167.82 g
Camera
Colour - Day&Night - fixed - indoor
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
7.62 m
Frame Rate (max)
Image Sensor
CMOS
Network Interface
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Wall mount bracket, PoE adapter
1 x USB cable - external
Power adapter - external
Internet of Things (IoT)
Platform
IFTTT
Communications Type
Cloud
Communications Technology
Wi-Fi
