Arlo Pro 2: The Dependable 1080p Wireless Camera
When it comes to security, trust a Pro. The next level 1080p HD security camera with total flexibility.
Peace of mind. Anytime. Anywhere.
1080p HD quality means you get videos with sharper details so you can see your home and everyone around it in more brilliant detail than ever before, day or night. No matter where you are.
Get the best of both worlds.
Use Arlo Pro 2 as a wire-free camera outdoors. When indoors, you can use Arlo Pro 2 either wire-free or plugged-in. Check in from anywhere to see if the kids are home from school or to keep them safely in sight while they’re out playing in the pool.
Watch over your pets from anywhere.
Whether they’re lounging inside or chasing squirrels outside, make sure your furry little trouble makers are out of harm’s way no matter where they are, from wherever you are.
Know who’s there. Instantly.
From welcomed guests to unwanted visitors, always know who’s coming and going. See something suspicious? Don’t just sit back and watch. You can protect your home by using the smart siren to scare off intruders.
Your World, Just a Tap Away
Stay in total control all the time. Whether you're using a smartphone, tablet, or computer, a click or two is all you'll ever need to check in. The free Arlo app is available for iOS, Android, Apple TV and web browser.
Be the First to Know
View live anytime and receive instant email or mobile alerts whenever motion or audio is detected.
Never Miss a Moment Again
Arlo records motion or sound-triggered events and saves them in your cloud Library to be viewed, downloaded, and shared for 7 days, for FREE
Get More Angles Covered
Expanding your Arlo system is a breeze. Connect up to five cameras for free. Upgrade to add up to 15 cameras per account.
Your Schedule. Your Terms.
Use smart scheduling to set Arlo's work schedule to fit yours. Geo-fencing, custom modes, and IFTTT are just a few of the possible ways to personalize your Arlo system to your needs and preferences.
Share the Action
Easily share camera access, or specific videos, with friends and family so everyone’s caught up on the latest events.
Cloud Storage: Archived Security Camera Recordings in 1080p
Why commit to a long-term contract or pay expensive monthly subscription fees? Arlo can save you hundreds of dollars a year.
The Arlo Basic plan gives you access to motion- and audio-triggered recordings from the past 7 days. And the plan never expires!
The Arlo Basic plan is included with every camera, for up to 5 cameras per account.
1080p HD quality
Watch and record crisp HD video in more detail than ever before. -
Sound and advanced motion detection
Get instant notifications sent to your smartphone or email. -
Activity zones
Highlight areas in your camera's view where you want to receive motion and sound alerts. Available when plugged in and used indoors. -
Optional 24/7 CVR
Upgrade to keep nonstop recordings in the cloud when the camera is plugged in and used indoors. -
3-second look back
Capture activity 3 seconds before a triggered event so you'll always know what happened, from start to finish. Available when plugged in and used indoors. -
Flexible powering options
Use it wire-free with the rechargeable battery. Or plug it in to an indoor power outlet to unlock advanced features. -
Weather-resistant
IP65-certified to stand the rain, sun, heat or chill. -
Rechargeable battery
Long lasting, takes the expense out of security. -
2-way audio
Listen in and talk back through the camera from your smartphone. -
Night vision
Turns on automatically in low light so you can see clearly, even in the dark. -
Free cloud storage
Keep a rolling 7 days of motion and sound-triggered recordings for free. -
Local backup storage
Connect a USB drive to the Arlo Pro 2 base station for optional local backup storage. -
Smart security siren
100+ decibel, controlled remotely or triggered by motion or sound. -
Plays well with others
Works with Apple HomeKit, Amazon Alexa, the Google Assistant, IFTTT & Stringify.
- Arlo Pro 2 VMS4230P - video server + camera(s) - wireless (802.11n)
- System
- Video server + camera(s) - wireless - IEEE 802.11n - 2.4 GHz
- Camera
- 2 cameras - outdoor - night vision
- Platform
- SmartThings
- Intelligent Assistant
- Alexa - indirect
- System
- Network Interface
- IEEE 802.11n
- Wireless Frequency Band
- 2.4 GHz
- 2-way audio, built-in microphone, built-in speaker, push notifications, infrared cut filter, motion detection, e-mail alerts, sound detection, 1080p HD video, weather-resistant, Smart Siren, geofencing
- Package Content
- Camera wall mount, power adapter, window decal, power cable, rechargeable batteries
- Cables Included
- Network cable - 1 pcs.
Video Server
- CPU
- ARM Cortex A7
- RAM
- 128 MB
- Flash Memory
- 128 MB
Cameras
- Quantity
- 2 cameras
- Camera Type
- Outdoor
- Sensor
- CMOS
- Field of View
- 130°
- Night Vision
- Infrared LEDs
- 850
- Infrared Distance
- 7.62 m
- White Balance
- Auto
- -20 °C
- 45 °C
- IP65
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Samsung SmartThings Hub
- Platform
- SmartThings
- Communications Technology
- Wi-Fi
- Compatible Services
- IFTTT
- Alexa
- Voice Controlled
- Indirect
- Details
- Video server: 5.86 cm x 17.45 cm x 12.65 cm - 316 g , Camera: 7.93 cm x 4.86 cm x 7.05 cm - 136 g
