Arlo Q 1080p HD Security Camera with Audio
NETGEAR ARLO Q - EVERY ANGLE COVERED
Quicklinx: BW82WS00 Mfr#: VMC3040-100UKS
See and hear everything that's happening at home in brilliant detail with the Arlo Q HD security camera. The high-definition 1080p video, night vision, and 2-way audio make sure you never miss a moment, and instant noise- and motion-detection alerts take the worry out of being away.
  • Be there instantly - no matter where you are
    A tap or two is all it takes to check in on your home or business from any computer or mobile device. Watch five live video streams at once. Create a customized motion and sound alert schedule to match your lifestyle. Arlo Q gives you permanent peace of mind.
  • Always watchful, always ready
    Arlo Q keeps an eye on what matters whenever you can't. Motion-sensing and sound-detection technologies trigger instant email alerts and push notifications the moment anything happens that shouldn't at home or work.
  • The simple setup in home security
    Connecting Arlo Q to your Wi-Fi network is very quick and easy. You're done in minutes. Place your cameras anywhere they're needed - mount them on walls, snap them onto metal surfaces using their built-in magnetic mounts, or simply place them on the flat surface of your choice.
  • Have a conversation
    The Arlo Q camera has a built-in speaker and microphone so you can talk with anyone who's there, help with homework, monitor your baby, shoo the dog off the couch, or join the party from anywhere in the world.
  • See every corner of the room
    Arlo Q uses an extra-wide 130-degree field of view to capture entire rooms from corner to corner. See it all without moving, panning, or zooming your cameras.
Arlo Q VMC3040 - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, built-in microphone
Wireless
Camera
Colour - Day&Night
Frame Rate (max)
30 frames per second
Video Modes
1080p
Optical Sensor Type
CMOS
Motion sensor, e-mail alerts, Push Notification, sound sensor, cloud recording
Audio Support
Wireless
United Kingdom
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
7.62 m
Frame Rate (max)
Image Sensor
CMOS
Lens Construction
Horizontal Field of View (degree)
130
Wall mount bracket
Power adapter
