The world’s first and only 100% wire-free, weatherproof, rechargeable HD smart security camera with audio and 130° viewing angle. Expand your Arlo security system with this wire-free HD camera with 2-way audio, motion detection, night vision and a rechargeable battery. Security so simple - just place Arlo weatherproof camera wherever you need them to cover every angle and keep your home safe and protected. The Arlo Pro add-on camera is compatible with the original Arlo base station.
Smart Features Overview
- 100% Wire-Free - Place it anywhere. No cords or wiring hassles.
- HD Quality - Live stream and watch recordings in more brilliant detail than ever before.
- Rechargeable - Long lasting rechargeable batteries take the expense out of uninterrupted security.
- Advanced Motion Detection - Wide-angle PIR motion sensor makes sure no movement will slip through without your notice.
- Free Cloud Storage - Don't pay for cloud storage that you don't need. Keep 7 days of motion- and audio-triggered recordings for free.
- Smart Siren - Stop crime before it happens with a 100+ decibel siren that can be controlled remotely, or triggered by motion or audio.
- Weatherproof - Rain or shine, hot or cold, the IP65-certified Arlo Pro camera will brave it all.
- 130° Viewing Angle - See more of every moment with a 130° wide-angle lens.
- 2-Way Audio - Listen in and talk back through the built-in speaker and mic, straight from your smartphone.
- Night Vision - Integrated night vision automatically switches on at night to shed light on the smallest wonders.
- Local Backup Storage - Connect a USB drive to the Arlo Pro base station for optional local backup storage.
- Flexible Powering Options - Use it wire-free or plugged in. The choice is yours.
Peace of Mind. Anytime. Anywhere.
Arlo Pro security cameras lets you watch over what you love from every angle, indoors and out, day and night.
Put an End to Daily Worries
No one can be in two places at once, but Arlo offers an extra set of eyes for you to get more done while keeping your kids and other loved ones always safely in sight.
Keep Your Home on Leash
Whether you need to know what mischief your furry friends are making, or just want to make sure they have enough supplies, Arlo can be there to see what happens when you're away and catch those YouTube-worthy moments on record.
Never Leave Home Alone
Sometimes it feels like it takes a village to run a household. Arlo helps you remotely keep tabs on all the activity and visitors, from delivery men and housekeepers to babysitters and yard help.
Your World, Just a Tap Away
Stay in total control all the time. Whether you're using a smartphone, tablet, or computer, a click or two is all you'll ever need to check in. The free Arlo app is available for iOS, Android, Apple TV and web browser.
- Be the First to Know - View live anytime and receive instant email or mobile alerts whenever motion or audio is detected.
- Never Miss a Moment Again - Arlo records motion or sound-triggered events and saves them in your cloud Library to be viewed, downloaded, and shared for 7 days, for FREE.
- Get More Angles Covered - Expanding your Arlo system is a breeze. Connect up to five cameras for free. Upgrade to add up to 15 cameras per account.
- Your Schedule. Your Terms. - Use smart scheduling to set Arlo's work schedule to fit yours. Geo-fencing, custom modes, and IFTTT are just a few of the possible ways to personalize your Arlo system to your needs and preferences.
- Share the Action - Easily share camera access, or specific videos, with friends and family so everyone’s caught up on the latest events.
Free Cloud Storage
- Why commit to a long-term contract or pay expensive monthly subscription fees? Arlo can save you hundreds of pounds a year.
- The Arlo Basic plan gives you access to motion- and audio-triggered recordings from the past 7 days for free. And the plan never expires!
- The Arlo Basic plan is included with every camera, for up to 5 cameras per account.
Arlo at your fingertips
Enjoy complete command of your connected home security cameras thanks to the free, highly rated Arlo App. Customize settings, communicate instantly and more. -
Built for the real world
Versatile magnetic mounts, weatherproof enclosures and superior battery life are just a few of Arlo’s enduring advantages.
- Arlo Pro VMS4330 - video server + camera(s) - wireless (802.11n)
- System
- Video server + camera(s) - wireless - IEEE 802.11n - 2.4 GHz
- Camera
- 3 cameras - outdoor - night vision
- 1 year
- System
- Network Interface
- IEEE 802.11n
- Wireless Frequency Band
- 2.4 GHz
- Package Content
- Camera wall mount, power adapter, window decal, power cable
- Cables Included
- Network cable - 1 pcs.
- Warranty
- 1 year
Cameras
- Quantity
- 3 cameras
- Camera Type
- Outdoor
- Field of View
- 130°
- Night Vision
- Infrared Distance
- 7.62 m
- -20 °C
- 45 °C
- IP65
- Details
- Video server: 5.86 cm x 17.45 cm x 12.65 cm - 316 g , Camera: 7.93 cm x 4.86 cm x 7.05 cm - 136 g
