Apple Wireless Charging Case for AirPods
Quicklinx: F48FWS00 Mfr#: MR8U2ZM/A
Accessory Type: Case
Connectivity: Wireless
Colour: White
14 In Stock
£65.84 ex VAT
£79.00 inc VAT
With the Wireless Charging Case, charging your earbuds is simple. The LED indicator on the front of the case lets you know that your earbuds are charging. And when you're away from a charging mat, you can use the Lightning port to charge.
Apple Wireless Charging Case charging case
Charging case
4.43 cm x 2.13 cm x 5.35 cm
40 g
Wireless Charging
Wireless Charging Standards
Qi
AirPods (1st generation, 2nd generation)
Charging case
Headphones
4.43 cm
2.13 cm
5.35 cm
40 g
Input Connectors
Apple Lightning
Input Connectors Qty
1
Wireless Charging
Qi
LED indicator
Apple AirPods (1st generation, 2nd generation)
F48F Apple Lightning to USB Cable (0.5m) In Stock £15.00
F48F Apple Lightning to USB Cable (2 m) In Stock £29.17
F48F Apple MagSafe Charger In Stock £35.84
F48F Apple USB-C to Lightning Cable (1 m) In Stock £14.33
F48F Apple USB-C to Lightning Cable 2m In Stock £26.59
Colour: White
Brand: Apple
