Your essential companion is even more powerful. Introducing temperature sensing for deeper insights into women's health. Crash Detection to get help in an emergency. Sleep stages to better understand your sleep. The future of health never looked so good.
Smooth and seamless
Apple Watch Series 8 features a big, brilliant Always-On display. Narrow borders push the screen right to the edge, resulting in an elegant integration with the curvature of the case.
Always-On Retina display
Take it all in. Get it all done. The bright Always-On screen makes detailed watch faces look stunning and easy to read, even when your wrist is down. The large display accommodates all your favorite complications and makes tapping, typing, and swiping a snap.
Tougher than tough
The same innovations used to create the beautiful, edge-to-edge Always-On display also help make it incredibly durable. A thick front crystal, robust geometry, and flat base make it resistant to cracking.
Advanced health sensors
The more informed you are about your health, the more empowered you are to affect it. Advanced health sensors in Apple Watch Series 8 provide insights to help you better understand your health.
Understand your cycle like never before
Apple Watch Series 8 has an innovative sensor that tracks your temperature while you sleep, so you can see changes over time. Cycle Tracking uses this data to provide a retrospective estimate of when you likely ovulated, which can be helpful for family planning. When combined with your heart rate and logged cycle data, you'll get a detailed view of your menstrual cycle.
Period predictions
Get improved period predictions with wrist temperature data. You can receive notifications if your logged cycle data shows a possible cycle deviation, like irregular or prolonged periods. You can share your cycle history with your healthcare provider for more informed conversations.
Crash Detection
Apple Watch Series 8 is able to detect if you're in a severe car crash. When a crash is detected, Crash Detection can automatically connect you with emergency services, provide dispatchers with your location, and notify your emergency contacts. Crash Detection uses the combined power of an improved 3-axis gyroscope and a g-force accelerometer that has the higher dynamic range. It also uses a microphone, barometer, GPS, and an advanced sensor-fusion algorithm trained on over 1 million hours of real-world driving and crash data to detect if you're in a severe crash.
Low Power Mode
You've got extra time on your hands. Get even more hours with the Low Power Mode. Great for occasions when you're away from your charger, like a long flight.
Smooth and seamless
Apple Watch Series 8 features a big, brilliant Always-On display. Narrow borders push the screen right to the edge, resulting in an elegant integration with the curvature of the case. -
Take it all in. Get it all done. The bright Always-On screen makes detailed watch faces look stunning and easy to read, even when your wrist is down. The large display accommodates all your favorite complications and makes tapping, typing, and swiping a snap. -
Tougher than tough
The same innovations used to create the beautiful, edge-to-edge Always-On display also help make it incredibly durable. A thick front crystal, robust geometry, and flat base make it resistant to cracking. -
The more informed you are about your health, the more empowered you are to affect it. Advanced health sensors in Apple Watch Series 8 provide insights to help you better understand your health. -
Apple Watch Series 8 has an innovative sensor that tracks your temperature while you sleep, so you can see changes over time. Cycle Tracking uses this data to provide a retrospective estimate of when you likely ovulated, which can be helpful for family planning. When combined with your heart rate and logged cycle data, you'll get a detailed view of your menstrual cycle. -
Period predictions
Get improved period predictions with wrist temperature data. You can receive notifications if your logged cycle data shows a possible cycle deviation, like irregular or prolonged periods. You can share your cycle history with your healthcare provider for more informed conversations. -
Crash Detection
Apple Watch Series 8 is able to detect if you're in a severe car crash. When a crash is detected, Crash Detection can automatically connect you with emergency services, provide dispatchers with your location, and notify your emergency contacts. Crash Detection uses the combined power of an improved 3-axis gyroscope and a g-force accelerometer that has the higher dynamic range. It also uses a microphone, barometer, GPS, and an advanced sensor-fusion algorithm trained on over 1 million hours of real-world driving and crash data to detect if you're in a severe crash. -
Low Power Mode
- Apple Watch Series 8 (GPS) - starlight aluminium - smart watch with sport band - starlight - 32 GB
- Product Type
- Smart watch
- Manufacturer Model Number
- A2770
- Tracking Data
- Distance, time, calories burned, activity, sleep activity, heart rate, blood oxygen saturation, sleep stages, menstrual cycle, ECG, ovulation phase, rapid eye movement (REM)
- Connectivity
- Wi-Fi, Bluetooth
- Navigation
- GPS/GLONASS/Galileo/BeiDou/QZSS receiver
- Display
- Retina LTPO OLED 352 x 430 pixels - Ion-X glass - always-on display
- Processor
- Apple S8 SiP
- Storage
- 32 GB
- Operating System
- WatchOS
- Case
- Rectangular - 41 mm - aerospace-grade aluminium alloy
- Band
- Starlight - sport band - fluoroelastomer - size: Regular - changeable
- Payment Technology
- Apple Pay
- Intelligent Assistant
- Siri
- Input
- Touch screen
- Fits Wrist with Circumference
- 130-200 mm
- Notifications
- Calendar, SMS, Email, high and low heart rate, irregular rhythm, cardio fitness
- Call handling, Fall detection, Emergency SOS, Family Setup support, International Emergency Calling, Crash Detection, noise monitoring, Compass Waypoint, brightness: 1000 nits, Edge-to-edge display
- Supported Host Device OS
- iOS
- Battery
- Rechargeable Lithium Ion
- Battery Run Time
- Up to 18 hours
- 35 mm x 10.7 mm x 41 mm
- 32 g
- Specific Absorption Rate (SAR)
- 0.17 W/kg (head) , 0.28 W/kg (limb)
- 1-year warranty
- Product Type
- Smart watch
- A2770
- iOS 16 or later
- Notifications
- Navigation
- Tracking Data
- Apple Pay
- Audio Input
- Microphone
- Audio Output
- Speaker
- Operating System
- WatchOS
- Wearing Style
- Watch style
- Feedback Type
- Audio alert, vibration alert, visual interface
- Clock Display
- Set Goals
- Sensors
- Accelerometer, ambient light sensor, digital compass, electrical heart sensor, blood oxygen sensor, gyroscope, temperature sensing, optical heart sensor (3d gen), always-on altimeter
Storage
- Capacity
- 32 GB
Display
- Retina LTPO OLED - colour
- Resolution
- 352 x 430 pixels
- Protection
- Ion-X glass
- Always On Display (AOD)
- Wireless Interface
- IEEE 802.11b/g/n, Bluetooth 5.0
Input Device
- Touch sensitive screen
CPU
- Manufacturer
- Apple
- S8 SiP
- W3 Apple wireless chip, U1 chip
- Technology
- Lithium Ion
- Rechargeable Battery
- Wireless Charging
- Run Time (Up To)
- 18 hours
Smart Watch Case
- Case Shape
- Rectangular
- Case Size
- 41 mm
- Crown Type
- Digital with haptic feedback
- Case Back
- Sapphire crystal and ceramic back
- Case Details
- Starlight aluminium
Band
- Name
- Sport band
- Changeable
- Size
- Regular
- 130-200 mm
- Clasp Type
- Pin-and-tuck
- Material
- Fluoroelastomer
- Starlight
- Details
- Case only: 32 g
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Siri
- Voice Controlled
- Direct
- Preloaded Software
- Apple Pay, GymKit
- Vibrating Alert
- Body Material
- Aerospace-grade aluminium alloy
- Protection
- Water-resistant, dust-resistant, crack-resistant
- IP6X
- Included Accessories
- Magnetic fast charger to USB-C cable (1 m)
- Warranty
- 1-year warranty
- Max Depth of Water Resistance
- 50 m
