Apple Watch Series 4 GPS + Cellular, 44mm Silver Aluminium Case with Seashell Sport Loop
Quicklinx: DSM9WS00 Mfr#: MTVT2B/A
Colours:
All new. For a better you.
Introducing Apple Watch Series 4. Fundamentally redesigned and re-engineered to help you stay even more active, healthy and connected.
  • Not just evolved, transformed
    Series 4 represents a fundamental redesign and re-engineering of Apple Watch. From the curved corners of the larger display to the architecture of the S4 chip, every detail has been thoughtfully considered. Apple Watch has always been a uniquely personal product. And now it's even more powerful.
  • Part guardian, part guru
    Apple Watch Series 4 inspires you to live a healthier life by helping you manage everything from everyday stress to calories burned. At the same time, it monitors your heart rate and lets you know if it detects something of concern. And that sense of security now goes a step further with fall detection and Emergency SOS.
  • Ultimate workout partner
    Apple Watch Series 4 is more than just a sports watch. It's like a trainer that understands the ways you work out - from running to yoga to swimming - and puts every metric you need right on your wrist.
  • Made to motivate
    Understanding all the ways you move throughout the day is an essential part of living a healthy life. Apple Watch shows your daily movement as three simple metrics: Move, Exercise, and Stand. Together they make up the Activity rings that track your progress all day long. The goal is to close your rings each day.
  • The freedom of cellular
    Take a call from the trail. Check in with a buddy over Walkie-Talkie. Keep your workouts going by streaming Apple Music. Or raise your wrist and ask Siri to order your usual. Apple Watch Series 4 with cellular makes it easy to stay connected to the people and information you care about most. Even when you don't have your phone.
Apple Watch Series 4 (GPS + Cellular) - silver aluminium - smart watch with sport loop - seashell - 16 GB - not specified
Smart watch
Operating System
Watch OS 5
Storage
16 GB
Wi-Fi, Bluetooth
Service Provider
Not specified
Apple S4
Supported Host Device OS
iOS
Cellular Messaging Services
SMS
Display
LTPO OLED 368 x 448 pixels
Input
Force Touch
Tracking Data
Distance, time, calories burned, activity, heart rate, steps taken, UV index, Air Quality index
Band
Seashell - sport loop - woven nylon - 145-220 mm
Heart rate sensor, navigation, music remote handling, microphone, EKG accurate heart rate, calendar notification, SMS notification, Email notification, listening to music, Retina Display technology, call alerts, automatic exercise recognition, Fall detection, Emergency SOS
Battery Run Time
Up to 18 hours
Case Size
44 mm
Case Material
Anodised aluminium
38 mm x 10.7 mm x 44 mm
36.7 g
Smart watch
Integrated Components
iOS
Supported Mobile Messaging Services
SMS
Tracking Data
Audio Output
Speaker
Operating System
Watch OS 5
Wearing Style
Watch style
Feedback Type
Audio alert, vibration alert, visual interface
Clock Display
Set Goals
Music remote handling, microphone, EKG accurate heart rate, calendar notification, SMS notification, Email notification, listening to music, Retina Display technology, call alerts, automatic exercise recognition, Fall detection, Emergency SOS, accelerometer, ambient light sensor, gyro sensor, barometric altimeter, optical heart sensor, electrical heart sensor
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
SIM Card Type
Electronic SIM card (e-SIM)
Storage
16 GB
Display
LTPO OLED - colour
Resolution
368 x 448 pixels
Protection
Ion-X glass
Wireless Interface
IEEE 802.11b/g/n, Bluetooth 5.0
Input Device
Touch sensitive screen (Force Touch)
CPU
Manufacturer
Apple
S4
W3 Apple wireless chip
Lithium Ion
Run Time (Up To)
18 hours
Smart Watch Case
Case Size
44 mm
Crown Type
Digital with haptic feedback
Case Back
All ceramic and sapphire crystal back
Case Details
Silver aluminium
Band
Name
Sport loop
Fits Wrist Size
145-220 mm
Clasp Type
Hook-and-loop
Material
Woven nylon
Seashell
38 mm
10.7 mm
44 mm
36.7 g
Vibrating Alert
Body Material
Anodised aluminium
Protection
Waterproof
Power adapter, magnetic charging cable
Max Depth of Water Resistance
50 m
