Apple Watch Series 3 GPS + Cellular, 42mm Stainless Steel Case with Milanese Loop
Quicklinx: D4Y0WS00 Mfr#: MR1U2B/A
Answer a call from your surfboard. Stream your favorite songs on your run. And do it all while leaving your phone behind. The Apple Watch Series 3 gives you the freedom to go with just your watch.
  • The watch reimagined
    It delivers important information when and where you need it. Helps you easily perform everyday tasks in seconds. Instantly connects you to the people and things you care about most. All while keeping precise time.
  • You'll know it when you feel it
    Because this smartwatch sits on your wrist, it can give you a gentle tap the instant you receive an alert.
  • Stay in touch like never before
    You won't just send and receive messages, calls, and mail more easily and efficiently. You'll express yourself in unique, fun, and more personal ways. Communicating with the smartphone is discreet, sophisticated, and nuanced - a different way to connect with others.
  • Messages, calls, and mail designed for your wrist
    The ways you communicate on your smartphone are even more immediate on the smartwatch. To read a message or email, just raise your wrist. You can take a quick phone call using the built-in speaker and microphone.
  • Easy ways to respond
    You don't always have time to craft a lengthy response to a message or email. With the smartwatch, you can make a quick but meaningful reply.
  • Say it with feeling
    You don't even have to use words. The Digital Touch feature gives you fun, spontaneous ways to connect with other smartwatch wearers, wrist to wrist.
  • Sensitive enough to tell a tap from a press
    In addition to recognizing touch, the smartwatch senses force, adding a different dimension to the user interface. With Force Touch, pressing firmly on the display brings up additional controls in apps.
  • Technology with a more human touch
    This linear actuator inside the smartwatch taps you on the wrist when you receive a notification, press down on the display, or use Digital Touch. The Taptic Engine gives different kinds of notifications and actions their own distinct character. So even with the accompanying audio cues turned off, you can feel the difference between an alarm and an incoming phone call without even looking.
Apple Watch Series 3 (GPS + Cellular) - stainless steel - smart watch with milanese loop - silver - 16 GB - not specified
Smart watch
Operating System
Watch OS 4
Storage
16 GB
Wi-Fi, Bluetooth
Service Provider
Not specified
Apple S3
Supported Host Device OS
iOS
Cellular Messaging Services
SMS
Display
OLED 312 x 390 pixels
Input
Force Touch
Tracking Data
Distance, time, calories burned, activity, heart rate, steps taken
Band
Silver - milanese loop - stainless steel - 150-200 mm
Heart rate sensor, navigation, call handling, music remote handling, microphone, calendar notification, SMS notification, Email notification, camera remote control, listening to music, Retina Display technology, text messages handling
Battery Run Time
Up to 18 hours
Case Size
42 mm
Case Material
Stainless steel
36.4 mm x 11.4 mm x 42.5 mm
52.8 g
Smart watch
Integrated Components
iOS 11 or later
Supported Mobile Messaging Services
SMS
Tracking Data
Audio Output
Speaker
Operating System
Watch OS 4
Wearing Style
Watch style
Clock Display
Set Goals
Call handling, music remote handling, microphone, calendar notification, SMS notification, Email notification, camera remote control, listening to music, Retina Display technology, text messages handling, accelerometer, ambient light sensor, gyro sensor, heart rate, barometric altimeter
Cellular
Mobile Broadband Generation
4G
Service Provider
Not specified
SIM Card Type
Electronic SIM card (e-SIM)
Storage
16 GB
Display
OLED - colour
Resolution
312 x 390 pixels
Protection
Sapphire glass
Wireless Interface
IEEE 802.11b/g/n, Bluetooth 4.2
Input Device
Touch sensitive screen (Force Touch)
CPU
Manufacturer
Apple
S3
W2 Apple wireless chip
Lithium Ion
Run Time (Up To)
18 hours
Smart Watch Case
Case Size
42 mm
Crown Type
Digital
Case Back
Ceramic back
Case Details
Stainless steel
Band
Name
Milanese loop
Fits Wrist Size
150-200 mm
Clasp Type
Magnetic closure
Material
Woven stainless steel mesh
Silver
36.4 mm
11.4 mm
42.5 mm
52.8 g
Preloaded Software
Siri
Vibrating Alert
Body Material
Stainless steel
Protection
Waterproof
Power adapter, magnetic charging cable
Max Depth of Water Resistance
50 m
