Apple Watch Series 3 GPS + Cellular, 42mm Space Grey Aluminium Case with Dark Olive Sport Loop
Quicklinx: D4XFWS00 Mfr#: MQKR2B/A
Answer a call from your surfboard. Stream your favorite songs on your run. And do it all while leaving your phone behind. The Apple Watch Series 3 gives you the freedom to go with just your watch.
  • The watch reimagined
    It delivers important information when and where you need it. Helps you easily perform everyday tasks in seconds. Instantly connects you to the people and things you care about most. All while keeping precise time.
  • You'll know it when you feel it
    Because this smartwatch sits on your wrist, it can give you a gentle tap the instant you receive an alert.
  • Stay in touch like never before
    You won't just send and receive messages, calls, and mail more easily and efficiently. You'll express yourself in unique, fun, and more personal ways. Communicating with the smartphone is discreet, sophisticated, and nuanced - a different way to connect with others.
  • Messages, calls, and mail designed for your wrist
    The ways you communicate on your smartphone are even more immediate on the smartwatch. To read a message or email, just raise your wrist. You can take a quick phone call using the built-in speaker and microphone.
  • Easy ways to respond
    You don't always have time to craft a lengthy response to a message or email. With the smartwatch, you can make a quick but meaningful reply.
  • Say it with feeling
    You don't even have to use words. The Digital Touch feature gives you fun, spontaneous ways to connect with other smartwatch wearers, wrist to wrist.
  • Sensitive enough to tell a tap from a press
    In addition to recognising touch, the smartwatch senses force, adding a different dimension to the user interface. With Force Touch, pressing firmly on the display brings up additional controls in apps.
  • Technology with a more human touch
    This linear actuator inside the smartwatch taps you on the wrist when you receive a notification, press down on the display, or use Digital Touch. The Taptic Engine gives different kinds of notifications and actions their own distinct character. So even with the accompanying audio cues turned off, you can feel the difference between an alarm and an incoming phone call without even looking.
Apple Watch Series 3 (GPS + Cellular) - space grey aluminium - smart watch with sport loop - dark olive - 16 GB
Smart watch
Tracking Data
Distance, time, calories burned, activity, heart rate, steps taken
Wi-Fi, Bluetooth 4G
Navigation
GPS/GLONASS/Galileo/QZSS receiver
Display
OLED 312 x 390 pixels - Ion-X glass
Apple S3
Storage
16 GB
Operating System
WatchOS 4
Case
42 mm - anodised aluminium
Band
Dark olive - sport loop - woven nylon
Intelligent Assistant
Siri
Input
Force Touch
Fits Wrist with Circumference
145-220 mm
Notifications
Calendar, SMS, Email
Call handling, music remote handling, camera remote control, listening to music, Retina Display technology, text messages handling
Supported Host Device OS
iOS
Lithium Ion
Battery Run Time
Up to 18 hours
36.4 mm x 11.4 mm x 42.5 mm
34.9 g
0.16 W/kg (head) , 0.18 W/kg (limb)
Smart watch
iOS 11 or later
Supported Mobile Messaging Services
SMS
Notifications
Messaging Services
SMS
Navigation
Tracking Data
Audio Input
Microphone
Audio Output
Speaker
Operating System
WatchOS 4
Wearing Style
Watch style
Clock Display
Set Goals
Sensors
Accelerometer, ambient light sensor, gyro sensor, heart rate, barometric altimeter
Cellular
Mobile Broadband Generation
4G
Service Provider
Not specified
SIM Card Type
Electronic SIM card (e-SIM)
Storage
16 GB
Display
OLED - colour
Resolution
312 x 390 pixels
Protection
Ion-X glass
Wireless Interface
IEEE 802.11b/g/n, Bluetooth 4.2
Input Device
Touch sensitive screen (Force Touch)
CPU
Manufacturer
Apple
S3
W2 Apple wireless chip
Lithium Ion
Run Time (Up To)
18 hours
Smart Watch Case
Case Size
42 mm
Crown Type
Digital
Case Back
Ceramic back
Case Details
Space grey aluminium
Band
Name
Sport loop
145-220 mm
Clasp Type
Hook-and-loop
Material
Woven nylon
Dark olive
36.4 mm
11.4 mm
42.5 mm
34.9 g
Internet of Things (IoT)
Siri
Preloaded Software
Siri
Vibrating Alert
Body Material
Anodised aluminium
Protection
Waterproof
Power adapter, magnetic charging cable
Max Depth of Water Resistance
50 m
