A solution that combines the MagSafe technology with inductive charging: it's a completely sealed system free of exposed contacts. And it's very forgiving, requiring no precise alignment. You simply hold the connector near the back of the watch, where magnets cause it to snap into place automatically.
- Apple Magnetic - smart watch charging cable - 30 cm
- Cable
- Smart watch charging cable
- Length
- 30 cm
- Connector
- USB - male
- Magnetic charging connection
- Cable Type
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
