Apple VESA Mount Adapter for Pro Display XDR
Quicklinx: FKXXWS00 Mfr#: MWUF2Z/A
Hurry, only 1 left in stock!
£152.65 ex VAT
£183.18 inc VAT
Express delivery Order within the next 3 hours for delivery tomorrow
For pros who use a VESA stand, mount, or arm instead of a traditional stand, the VESA Mount Adapter is the perfect way to seamlessly add Pro Display XDR to your workspace. It works with any VESA-compatible 100 by 100 mm wall mount, desk mount, stand, or articulating arm that can support the 16.49-pound (7.48 kg) Pro Display XDR. And it can be placed and secured quickly and easily using the included Apple-designed lock key.
Apple VESA Mount Adapter - mounting component
Mounting component
Mounting Components
VESA mount bracket
11.9 cm x 1.83 cm x 11.9 cm
280 g
Recommended Use
Monitor
VESA Mounting Interface
100 x 100 mm
Package Content
Pro Display XDR
11.9 cm
1.83 cm
11.9 cm
280 g
Package Content
AV Furniture
Mounting component
Mounting Components
VESA mount bracket
Recommended Use
Monitor
100 x 100 mm
Apple Pro Display XDR
Brand: Apple
Stock Status: In stock
