The Apple USB Ethernet Adapter is a simple, one-piece external adapter that plugs into the USB 2.0 port of your MacBook Air to provide 10/100BASE-T performance. Simply plug your Ethernet cable into the RJ-45 connector - no external power is required. It's small, light, easy to install, and even easier to use.
- Apple USB Ethernet Adapter - network adapter - USB 2.0 - 10/100 Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- 10/100 Ethernet
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- Data Transfer Rate
- 100 Mbps
- USB 2.0
- System Requirements
- Apple MacOS X 10.4.8 or later
- Designed For
- MacBook Air
- Network adapter
- Form Factor
- External
- USB 2.0
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet
- 100 Mbps
- USB powered
- USB 2.0
- 1 x 100Base-TX - RJ-45
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable (integrated) - 11.7 cm
- OS Required
- Designed For
- Apple MacBook Air
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.80 |
