Apple USB-C VGA Multiport Adapter
Quicklinx: B8SDWS00 Mfr#: MJ1L2ZM/A
18 in stock
£59.39 ex VAT
£71.26 inc VAT
The USB-C VGA Multiport Adapter lets you connect your MacBook with USB-C port to a VGA display, while also connecting a standard USB device and a USB-C charging cable. The USB-C VGA Multiport Adapter allows you to mirror your MacBook display to your VGA-enabled TV or display in up to 1080p HD. It also outputs video content like films and captured video. Simply connect the adapter to the USB-C port on your MacBook and then to your TV or projector via a VGA cable (sold separately). Use the standard USB port to connect devices such as your flash drive or camera, or a USB cable for syncing and charging your iPhone, iPad or iPod. You can also connect a charging cable to the USB-C port to charge your MacBook.
Apple USB-C VGA Multiport Adapter - VGA adapter
VGA adapter
Sync and charge
Connectors
USB-C - male
Connectors (Second End)
USB-C - female , HD-15 (VGA) - female , USB Type A - female
10.9-inch iPad Air (4th generation); 11-inch iPad Pro (1st generation, 2nd generation); 12.9-inch iPad Pro; iMac (Early 2019, Mid 2017); iMac Pro (Late 2017); Mac mini (Early 2020, Late 2018); Mac Pro (Late 2019); MacBook; MacBook Air (Late 2018, Mid 2019), with Retina display; MacBook Pro
VGA adapter
Sync and charge
Connectors
24 pin USB-C - male
24 pin USB-C - female , 15 pin HD D-Sub (HD-15) - female , 9 pin USB Type A - female
Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation) , Apple iMac (Early 2019, Mid 2017) , Apple iMac Pro (Late 2017) , Apple Mac mini (Early 2020, Late 2018) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Late 2018, Mid 2019), with Retina display (Early 2020, Late 2018, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Mid 2017, Mid 2018, Mid 2019)
Brand: Apple
Stock Status: In stock
