Apple USB-C to SD Card Reader
Quicklinx: DXH5WS00 Mfr#: MUFG2ZM/A
£31.35 ex VAT
£37.62 inc VAT
The USB-C to SD Card Reader transfers high-resolution photos and videos at UHS-II speeds to your USB-C-enabled Mac, iPad or iPhone. Designed so it won’t block your other ports, it works with UHS-II SD cards and is backwards-compatible with other SD cards and adapters.
Apple USB-C to SD Card Reader - card reader - USB-C
Card reader - external
Supported Memory Cards
SD Memory Card
Host Interface
USB-C
SD Memory Card
Host Interface
USB-C
Memory Card
(max)
Required Ports
1 x 24 pin USB-C
