Brand
Apple USB-C to Lightning Cable 2m
Quicklinx: GR91WS00 Mfr#: MQGH2ZM/A
Product Range: Apple
Hurry, only 1 left in stock!
£32.53 ex VAT
£39.03 inc VAT
Connect your iPhone, iPad, or iPod with Lightning connector to your USB-C - or Thunderbolt 3 (USB-C) - enabled Mac for syncing and charging, or to your USB-C - enabled iPad for charging.
You can also use this cable with your Apple 18W, 20W, 29W, 30W, 61W, 87W or 96W USB-C Power Adapter to charge your iOS device and even take advantage of the fast-charging feature on selected iPhone and iPad models.
Apple Lightning cable - Lightning / USB - 2 m
Cable
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
Lightning - male
1-year warranty
Apple Wireless Charging Case; 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; AirPods; AirPods Max; AirPods Pro; iMac Pro; iPad mini 2; 4; 5; iPad with Retina display; iPhone 11, 12, 13, 14, 6s, 7, 8, SE, X, XR, XS, XS Max; MacBook Pro
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Length
2 m
Recommended Use
Mobile phone, tablet, digital player
Connector
24 pin USB-C - male
Apple Lightning - male
Limited warranty - parts and labour - 1 year
Apple Wireless Charging Case , Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple AirPods (1st generation, 2nd generation, 3rd generation) , Apple AirPods Max , Apple AirPods Pro (1st generation, 2nd generation) , Apple iMac (Early 2019, Early 2021, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017, Mid 2020) , Apple iPad Air , Apple iPad Air 2 (2nd generation) , Apple iPad mini (1st generation) , Apple iPad mini 2 (2nd generation) , Apple iPad mini 3 (3rd generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 14, 14 Plus, 14 Pro, 14 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), SE (3rd generation), X, XR, XS, XS Max , Apple iPod nano (7G) , Apple iPod touch (5G, 6G, 7G) , Apple Mac mini (Early 2020, Late 2018, Late 2020) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Late 2020, Mid 2019, Mid 2022) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Late 2021, Mid 2017, Mid 2018, Mid 2019, Mid 2022)
Brand: Apple
Stock Status: In stock
