Brand
Apple USB-C to Lightning Cable (1 m)
Quicklinx: GK11WS00 Mfr#: MM0A3ZM/A
Hurry, only 1 left in stock!
£13.86 ex VAT
£16.63 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
Connect your iPhone, iPad or iPod with Lightning connector to your USB-C- or Thunderbolt 3 (USB-C)-enabled Mac for syncing and charging, or to your USB-C-enabled iPad for charging.
You can also use this cable with your Apple 18W, 20W, 29W, 30W, 61W, 87W or 96W USB-C power adapter to charge your iOS device and even take advantage of the fast-charging feature.
Apple USB-C to Lightning Cable - Lightning cable - Lightning / USB - 1 m
Cable
Length
1 m
Connector
USB-C - male
Connector (Second End)
Lightning - male
Thunderbolt 3
1-year warranty
10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 10.9-inch iPad Air; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iMac; iMac Pro; iPad Air 2; iPad mini; iPad mini 2; 4; 5; iPhone 11, 12, 13, 5c, 6s, 7, 8, SE, X, XR, XS, XS Max; Mac mini; MacBook Air; MacBook Pro
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Thunderbolt 3
Length
1 m
Recommended Use
Mobile phone, tablet, digital player
Connector
24 pin USB-C - male
Apple Lightning - male
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Early 2021, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini (1st generation, 6th generation) , Apple iPad mini 2 (2nd generation) , Apple iPad mini 3 (3rd generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod nano (7G) , Apple iPod touch (5G, 6G, 7G) , Apple Mac mini (Early 2020, Late 2018, Late 2020) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Late 2020, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Late 2021, Mid 2017, Mid 2018, Mid 2019)
Brand: Apple
Stock Status: In stock
