Connect your iPhone, iPad or iPod with Lightning connector to your USB-C- or Thunderbolt 3 (USB-C)-enabled Mac for syncing and charging, or to your USB-C-enabled iPad for charging.
You can also use this cable with your Apple 18W, 20W, 29W, 30W, 61W, 87W or 96W USB-C power adapter to charge your iOS device and even take advantage of the fast-charging feature.
- Apple USB-C to Lightning Cable - Lightning cable - Lightning / USB - 1 m
- Cable
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Lightning - male
- Thunderbolt 3
- 1-year warranty
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Thunderbolt 3
- Length
- 1 m
- Recommended Use
- Mobile phone, tablet, digital player
- Connector
- Apple Lightning - male
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GK11 048292 Condition: Customer return - item has been used but is in excellent condition |
£10.05 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
