Apple USB-C Digital AV Multiport Adapter - Docking station
Quicklinx: FDWWWS00 Mfr#: MUF82ZM/A
More than 50 In Stock
£60.29 ex VAT
£72.34 inc VAT
The USB-C Digital AV Multiport Adapter lets you connect your USB-C-enabled Mac or iPad Pro to an HDMI display, while also connecting a standard USB device and a USB-C charging cable. This adapter allows you to mirror your Mac display to your HDMI-enabled TV or display.
Apple Digital AV Multiport Adapter - adapter - HDMI / USB
Cable
Adapter - HDMI / USB
Max Output Resolution
3840 x 2160 - 60 Hz
Connectors
24 pin USB-C - male
Connectors (Second End)
HDMI - female , USB - female , USB-C (power only) - female
Thunderbolt 3
4K support
Cable Type
Adapter 4K support
Interface Supported
HDMI / USB
Thunderbolt 3
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connectors
24 pin USB-C - male
19 pin HDMI Type A - female , 4 pin USB Type A - female , 24 pin USB-C (power only) - female
