This 1-meter charge cable — with USB-C connectors on both ends — is ideal for charging, syncing, and transferring data between USB-C devices. Pair the USB-C Charge Cable with a compatible USB-C power adapter to conveniently charge your devices from a wall outlet and take advantage of fast-charging capabilities.
- Apple USB-C Charge Cable - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB-C cable
- Length
- 1 m
- Connector
