Apple USB-C Charge Cable
Quicklinx: GR6XWS00 Mfr#: MM093ZM/A
This 1-meter charge cable — with USB-C connectors on both ends — is ideal for charging, syncing, and transferring data between USB-C devices. Pair the USB-C Charge Cable with a compatible USB-C power adapter to conveniently charge your devices from a wall outlet and take advantage of fast-charging capabilities.
Apple USB-C Charge Cable - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB-C cable
Length
1 m
Connector
24 pin USB-C - male
24 pin USB-C - male
