Apple Thunderbolt to Gigabit Ethernet Adapter
Quicklinx: 84ZHWS00 Mfr#: MD463ZM/A
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: Mac
Type: Network adapter
£24.40 ex VAT
£29.28 inc VAT
The Apple Thunderbolt to Gigabit Ethernet Adapter lets you easily connect to a high-performance Gigabit Ethernet network. Small and compact, it connects to the Thunderbolt port on your Mac computer and provides an RJ-45 port that supports 10/100/1000BASE-T networks.
Compatibility
  • Mac: OS X v10.7.4 or later
  • Thunderbolt-equipped Mac computer
What's in the Box?
  • Apple Thunderbolt to Gigabit Ethernet Adapter with built-in Thunderbolt cable
Apple Thunderbolt to Gigabit Ethernet Adapter - network adapter
Network adapter
External
Interface (Bus) Type
Thunderbolt
Ports
Gigabit Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
Apple MacOS X 10.7.4 or later
iMac; Mac mini; MacBook Air; MacBook Pro
Network adapter
External
Thunderbolt
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
1 x 1000Base-T - RJ-45 - female
Apple iMac , Apple Mac mini , Apple MacBook Air , Apple MacBook Pro
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 84ZH 042953
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £17.61
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Brand: Apple
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
