This 0.8-meter cable supports Thunderbolt 3 data transfer up to 40 Gbps, USB 3.1 Gen 2 data transfer up to 10 Gbps, DisplayPort video output (HBR3), and charging up to 100 W. Use this cable to connect a Mac with Thunderbolt 3 (USB-C) to Thunderbolt 3 devices such as docks, hard drives, and displays. You can daisy-chain up to six Thunderbolt 3 devices.
- Apple - Thunderbolt cable - 24 pin USB-C to 24 pin USB-C - 80 cm
- Thunderbolt cable
- Up to 100 Watts of power delivery
- Length
- 80 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB 3.1 Gen 2 / Thunderbolt 3
- Designed For
- 10.9-inch iPad Air (4th generation); 11-inch iPad Pro; 12.9-inch iPad Pro; iMac; iMac Pro (Late 2017); iPad mini (6th generation); Mac mini (Early 2020, Late 2018, Late 2020); Mac Pro (Late 2019); MacBook (Early 2015, Early 2016, Mid 2017); MacBook Air; MacBook Pro
- Thunderbolt cable
- Length
- 80 cm
- Connector
- Designed For
- Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation) , Apple iMac (Early 2019, Early 2021, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad mini (6th generation) , Apple Mac mini (Early 2020, Late 2018, Late 2020) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Late 2020, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Mid 2017, Mid 2018, Mid 2019)
