Brand
Apple Smart Cover for iPad (8th generation) - Deep Navy
Quicklinx: FYWLWS00 Mfr#: MGYQ3ZM/A
Colour: Deep navy
£36.99 ex VAT
£44.38 inc VAT
The Smart Cover for iPad is constructed from a single piece of polyurethane to protect the front of your device. It automatically wakes your iPad when opened and puts it to sleep when closed. You can easily fold the Smart Cover into different positions to create a stand for reading, viewing, typing, or making FaceTime calls. And it's easy to remove, so you can snap it on and off whenever you want.
Apple Smart - flip cover for tablet
Flip cover for tablet
Material
Polyurethane
Deep navy
1-year warranty
10.2-inch iPad (7th generation, 8th generation, 9th generation); 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro
Material
Polyurethane
Deep navy
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Flip cover
Open Type
Side
Closure Type
Magnetic closure with sleep/wake feature
Cover Features
Stand function
1-year warranty
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro
Colour: Deep navy
Brand: Apple
