The Smart Cover for iPad is constructed from a single piece of polyurethane to protect the front of your device. It automatically wakes your iPad when opened and puts it to sleep when closed. You can easily fold the Smart Cover into different positions to create a stand for reading, viewing, typing, or making FaceTime calls. And it's easy to remove, so you can snap it on and off whenever you want.
- Apple Smart - flip cover for tablet
- Product Type
- Flip cover for tablet
- Material
- Polyurethane
- Cyprus green
- 1-year warranty
- Designed For
- 10.2-inch iPad (7th generation, 8th generation, 9th generation); 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro
- Material
- Polyurethane
- Cyprus green
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Cover Type
- Flip cover
- Open Type
- Side
- Closure Type
- Magnetic closure with sleep/wake feature
- Cover Features
- Stand function
- 1-year warranty
- Designed For
- Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro
