Apple Pencil
Quicklinx: BRJZWS00 Mfr#: MK0C2ZM/A
Device Type: Apple Pencil
Type: Stylus
Device Screen Size: [N/A]
Colour: [N/A]
Stock Status: In Stock, Used Stock
More than 50 in stock
£74.17 ex VAT
£89.00 inc VAT
Apple Pencil expands the power of iPad and opens up new creative possibilities. It's sensitive to pressure and tilt so you can easily vary line weight, create subtle shading, and produce a wide range of artistic effects - just like with a conventional pencil, but with pixel-perfect precision.
Compatible with:
  • iPad Air (3rd generation)
  • iPad mini (5th generation)
  • iPad (7th generation)
  • iPad (6th generation)
  • iPad Pro 12.9-inch (2nd generation)
  • iPad Pro 12.9-inch (1st generation)
  • iPad Pro 10.5-inch
  • iPad Pro 9.7-inch
Apple Pencil - stylus for tablet
Stylus
Intended For
Tablet
Wireless Interface
Bluetooth
Package Content
Stylus, pen tip, lightning adapter
10.2-inch iPad (7th generation); 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro; 12.9-inch iPad Pro (1st generation, 2nd generation); 9.7-inch iPad (6th generation); 9.7-inch iPad Pro; iPad mini 5
Stylus
Intended For
Tablet
Wireless Interface
Bluetooth
Package Content
Apple Lightning - Lightning
Apple 10.2-inch iPad (7th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (6th generation) , Apple 9.7-inch iPad Pro , Apple iPad mini 5
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: BRJZ 042315
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £40.28
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Stylus
Colour: [N/A]
Brand: Apple
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
