The Apple Pencil delivers pixel-perfect precision and industry-leading low latency, making it great for drawing, sketching, coloring, taking notes or even marking up emails, and more. And it's as easy and natural to use as a pencil. The Apple Pencil also features an intuitive touch surface that supports double-tapping. So now you can change tools without setting it down. It also features a flat edge that attaches magnetically for automatic charging and pairing.
Compatible with:
iPad Pro 12.9-inch
- 6th generation
- 5th generation
- 4th generation
- 3rd generation
iPad Pro 11-inch
- 4th generation
- 3rd generation
- 2nd generation
- 1st generation
iPad Air
- 5th generation
- 4th generation
iPad mini
- 6th generation
- Apple Pencil 2nd Generation - stylus for tablet
- Product Type
- Stylus
- Intended For
- Tablet
- Wireless Interface
- Bluetooth
- 0.89 cm x 0.89 cm
- Length
- 16.6 cm
- 20.7 g
- Designed For
- 10.9-inch iPad Air (4th gen, 5th gen); 11-inch iPad Pro (1st gen, 2nd gen, 3rd gen, 4th gen); 12.9-inch iPad Pro (3rd gen, 4th gen, 5th gen, 6th gen)
- Product Type
- Stylus
- Intended For
- Tablet
- Bluetooth
- 0.89 cm
- 0.89 cm
- Length
- 16.6 cm
- 20.7 g
- Designed For
- Apple 10.9-inch iPad Air (4th generation, 5th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation, 6th generation)
