Apple Mini DisplayPort to DVI Adapter
Quicklinx: 8FPDWS00 Mfr#: MB570Z/B
Every Mac with a Mini DisplayPort allows you to connect an external display or projector using an adapter. You can use an external display as your main workspace or to extend your desktop, or you can work in mirrored mode with a projector so you can view what your audience sees.
The Apple Mini DisplayPort to dual-link DVI adapter works best with displays that operate at dual-link resolutions, which are resolutions above 1920 x 1200. For displays that do not support dual-link DVI resolutions (displays that operate at resolutions of 1920 x 1200 or lower) you should use the Apple Mini DisplayPort to DVI adapter.
Apple DVI adapter
DVI adapter
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - female
DVI adapter
Connector
24+1 pin digital DVI - female
