Apple Mini DisplayPort to DVI Adapter
Quicklinx: 8FPDWS00 Mfr#: MB570Z/B
Hurry, only 1 left in stock!
£23.46 ex VAT
£28.15 inc VAT
Every Mac with a Mini DisplayPort allows you to connect an external display or projector using an adapter. You can use an external display as your main workspace or to extend your desktop, or you can work in mirrored mode with a projector so you can view what your audience sees.
The Apple Mini DisplayPort to dual-link DVI adapter works best with displays that operate at dual-link resolutions, which are resolutions above 1920 x 1200. For displays that do not support dual-link DVI resolutions (displays that operate at resolutions of 1920 x 1200 or lower) you should use the Apple Mini DisplayPort to DVI adapter.
Apple DVI adapter
DVI adapter
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - female
iMac; Mac mini (Early 2009, Late 2009, Late 2012, Late 2014, Mid 2010, Mid 2011); MacBook (Late 2008, Late 2009, Mid 2010); MacBook Air (Early 2014, Early 2015, Late 2008, Late 2010, Mid 2009, Mid 2011, Mid 2012, Mid 2013, Mid 2017); MacBook Pro
DVI adapter
Connector
24+1 pin digital DVI - female
Apple iMac (Early 2009, Late 2009, Late 2011, Late 2012, Late 2013, Late 2014, Late 2015, Mid 2010, Mid 2011, Mid 2014, Mid 2015) , Apple Mac mini (Early 2009, Late 2009, Late 2012, Late 2014, Mid 2010, Mid 2011) , Apple MacBook (Late 2008, Late 2009, Mid 2010) , Apple MacBook Air (Early 2014, Early 2015, Late 2008, Late 2010, Mid 2009, Mid 2011, Mid 2012, Mid 2013, Mid 2017) , Apple MacBook Pro (Early 2009, Early 2011, Early 2013, Early 2015, Late 2008, Late 2011, Late 2012, Late 2013, Mid 2009, Mid 2010, Mid 2012, Mid 2014, Mid 2015)
Brand: Apple
Price Range Ex VAT: 0 - 50
