Apple Mini DisplayPort To Dual Link DVI Adapter
Quicklinx: 5FC9WS00 Mfr#: MB571Z/A
The MacBook, MacBook Pro, and MacBook Air each have a Mini DisplayPort that allows you to connect an external display or projector using an adapter. You can use an external display as your main workspace or to extend your desktop, or you can work in mirrored mode with a projector so you can view what your audience sees.
Use the Mini DisplayPort to Dual-Link DVI Adapter to connect your MacBook, MacBook Pro, or MacBook Air to a 30-inch display, such as the 30-inch Apple Cinema Display HD, and enjoy the ultimate widescreen canvas with a resolution of 2560 by 1600 pixels.
Apple DVI adapter
DVI adapter - dual link
Connectors
Mini DisplayPort - male , USB - male
Connectors (Second End)
DVI-D - female , USB - female
DVI adapter
TMDS Links
Dual link
Connectors
Mini DisplayPort - male , 4 pin USB Type A - male
24+1 pin digital DVI - female , 4 pin USB Type A - female
